- 簡介
組裝電腦的用意在,從筆電換到桌機,改善在3d遊戲的效能。並用在程式、興趣與遊戲,能兩者都善用到。程式上在跑python機器學習,興趣學個照片、影片編輯,在遊戲上,要能跑得動高幀數或複雜地形。
能用於以後大學和工作需求,承載夢想的主機:藍航。
- 組裝菜單與選件原因
主機板: 技嘉 B660M GAMING X AX DDR4(M-ATX/1H1P/Realtek 2.5G+Wi-Fi 6) 8+2+1相電源, $4990
- 本身有散熱板
- 一體式I/O擋板能方便裝機
- 電源輸入精準和高速度
記憶體: 十銓 T-Force Vulcan 火神散熱片系列 32GB(雙通16GB*2) DDR5-5200/CL40 黑色, $4899
- 有搭配超導熱背膠,可以幫助散熱,使電腦溫度不易升高
- 它的設計有機械風格,十分美觀
固態硬碟SSD: 威剛 XPG S70BLADE 1T/Gen4 讀:7400M/寫:5500M/ DRAM快取/五年/贈散熱片, $2850
- 有五年的保固
- 在讀、寫速度上,能快速傳送、使用資料
顯示卡: INNO3D RTX3050 GAMING X2 OC(1830MHZ/24cm/註冊四年保), $8888
- 有四年的保固
- 散熱好,價格合理
機殼加電源: Montech SKY TWO 藍 顯卡長40/CPU高16.8/創新風流設計/玻璃透側/ATX, $2790
- 預裝四顆ARGB PWM風扇,對排熱有極佳的用處
- 有整線設計,讓線也有一定美觀
We only provide support in English. I have translated your question.
"Introduction
The purpose of assembling a computer is to change from a laptop to a desktop to improve performance in 3D games. And use it in programs, hobbies and games, both of which can be used well. On the program, I am running python machine learning. I am interested in learning photo and video editing. On the game, I must be able to run high frame rate or complex terrain.
It can be used for future university and work needs, and hosts the host of dreams: Lanhang.
Assembly menu and option reasons
Motherboard: Gigabyte B660M GAMING X AX DDR4(M-ATX/1H1P/Realtek 2.5G+Wi-Fi 6) 8+2+1 phase power supply, $4990
It has heat sink
Integrated I/O baffle for easy installation
Power input precision and high speed
Memory: Team Group T-Force Vulcan Heatsink Series 32GB (dual pass 16GB*2) DDR5-5200/CL40 black, $4899
It is equipped with superconducting thermal adhesive, which can help dissipate heat and make the computer temperature not easy to rise
Its design has a mechanical style and is very beautiful
SSD: ADATA XPG S70BLADE 1T/Gen4 Read: 7400M/Write: 5500M/ DRAM cache/five years/free heat sink, $2850
Comes with a five-year warranty
In terms of read and write speed, it can quickly transmit and use data
Graphics card: INNO3D RTX3050 GAMING X2 OC (1830MHZ/24cm/registered four-year warranty), $8888
Comes with a four-year warranty
Good cooling, reasonable price
Chassis plus power supply: Montech SKY TWO blue graphics card length 40/CPU height 16.8/innovative airflow design/glass transparent side/ATX, $2790
Four ARGB PWM fans are pre-installed, which is very useful for heat dissipation
There is a whole line design, so that the line is also beautiful"
Does this reflect your question correctly?
We have not heard back from you. Could you please give us an update?
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
![](/skins/images/4399995709D76C02984DDB9A1DB96C28/responsive_peak/images/icon_anonymous_message.png)
