Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1527 Discussions
藍航-載著生活與夢想出航
zena
  • 簡介
組裝電腦的用意在,從筆電換到桌機,改善在3d遊戲的效能。並用在程式、興趣與遊戲,能兩者都善用到。程式上在跑python機器學習,興趣學個照片、影片編輯,在遊戲上,要能跑得動高幀數或複雜地形。
能用於以後大學和工作需求,承載夢想的主機:藍航。
  • 組裝菜單與選件原因
主機板: 技嘉 B660M GAMING X AX DDR4(M-ATX/1H1P/Realtek 2.5G+Wi-Fi 6) 8+2+1相電源, $4990
  • 本身有散熱板
  • 一體式I/O擋板能方便裝機
  • 電源輸入精準和高速度
記憶體: 十銓 T-Force Vulcan 火神散熱片系列 32GB(雙通16GB*2) DDR5-5200/CL40 黑色, $4899
  • 有搭配超導熱背膠,可以幫助散熱,使電腦溫度不易升高
  • 它的設計有機械風格,十分美觀
固態硬碟SSD: 威剛 XPG S70BLADE 1T/Gen4 :7400M/:5500M/ DRAM快取/五年/贈散熱片, $2850
  • 有五年的保固
  • 在讀、寫速度上,能快速傳送、使用資料
顯示卡: INNO3D RTX3050 GAMING X2 OC(1830MHZ/24cm/註冊四年保), $8888
  • 有四年的保固
  • 散熱好,價格合理
機殼加電源: Montech SKY TWO 藍 顯卡長40/CPU16.8/創新風流設計/玻璃透側/ATX, $2790
  • 預裝四顆ARGB PWM風扇,對排熱有極佳的用處
  • 有整線設計,讓線也有一定美觀
AthiraM_Intel
We only provide support in English. I have translated your question.
"Introduction
The purpose of assembling a computer is to change from a laptop to a desktop to improve performance in 3D games. And use it in programs, hobbies and games, both of which can be used well. On the program, I am running python machine learning. I am interested in learning photo and video editing. On the game, I must be able to run high frame rate or complex terrain.
It can be used for future university and work needs, and hosts the host of dreams: Lanhang.
Assembly menu and option reasons
Motherboard: Gigabyte B660M GAMING X AX DDR4(M-ATX/1H1P/Realtek 2.5G+Wi-Fi 6) 8+2+1 phase power supply, $4990
It has heat sink
Integrated I/O baffle for easy installation
Power input precision and high speed
Memory: Team Group T-Force Vulcan Heatsink Series 32GB (dual pass 16GB*2) DDR5-5200/CL40 black, $4899
It is equipped with superconducting thermal adhesive, which can help dissipate heat and make the computer temperature not easy to rise
Its design has a mechanical style and is very beautiful
SSD: ADATA XPG S70BLADE 1T/Gen4 Read: 7400M/Write: 5500M/ DRAM cache/five years/free heat sink, $2850
Comes with a five-year warranty
In terms of read and write speed, it can quickly transmit and use data
Graphics card: INNO3D RTX3050 GAMING X2 OC (1830MHZ/24cm/registered four-year warranty), $8888
Comes with a four-year warranty
Good cooling, reasonable price
Chassis plus power supply: Montech SKY TWO blue graphics card length 40/CPU ​​height 16.8/innovative airflow design/glass transparent side/ATX, $2790
Four ARGB PWM fans are pre-installed, which is very useful for heat dissipation
There is a whole line design, so that the line is also beautiful"
Does this reflect your question correctly?
AthiraM_Intel
We have not heard back from you. Could you please give us an update?
AthiraM_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
