Hi
u180364@login-2:~$ qsub -I
socket_connect_unix failed: 15137
qsub: cannot connect to server (null) (errno=15137) could not connect to trqauthd
u180364@login-2:~$ qstat
qstat: cannot connect to server (null) (errno=15137) could not connect to trqauthd
qstat: Error (15137 - could not connect to trqauthd)
Any ideas on how to correct this?
Using the JupyterLab terminal, everything is working fine, but connecting via ssh this problem occurs.
Thanks in advance.
Thank you for posting in Intel communities.
We are sorry for the inconvenience caused. The issue has been resolved. Could you please verify from your end and let us know?
Thanks for the answer, I can confirm that the problem is solved.
Best,
Glad to know that your issue is resolved. If you need further assistance, please post a new question as this thread will no longer be monitored by Intel.
