What is the instruction to view the gpu information of the devcloud server。
Kindly execute the following commands to get information regarding the GPU.
1) To access a new GPU node:
qsub -I -l nodes=1:gpu:ppn=2 -d .
2) To display information about the GPU:
sycl-ls
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Thasneem Vazim
We have not heard back from you. Could you please give us an update?
Thasneem Vazim
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thasneem Vazim
