I want to compile a C++ application that requires OpenCV. Is OpenCV available on DevCloud? What should be the include path to compile with g++? And how do I link the executable to the OpenCV libraries?
OpenCV does not fall under the scope of oneAPI DevCloud. As such we will not install it.
oneAPI DevCloud users have the opportunity to build it from source.
Here's a general idea of the steps you can take in order to build it from source:
git clone https://github.com/opencv/opencv.git
cd opencv
mkdir build
cd build
cmake -D INSTALL_PYTHON_EXAMPLES=ON -D INSTALL_C_EXAMPLES=ON ..
make -j$(nproc)
More info on the OpenCV official pages: https://docs.opencv.org/4.x/d7/d9f/tutorial_linux_install.html
If this resolves your issue, make sure to accept this as a solution. This helps others with similar issue.
Alekhya
Thank you for posting in Intel Communities. Could you please let us know which DevCloud you're using? Is it DevCloud for oneAPI or DevCloud for Edge or DevCloud for FPGA?
Alekhya
Alekhya
It's DevCloud for oneAPI. So far, the only solution I've found is building OpenCV locally. Is there another way to use OpenCV in DevCloud for oneAPI?
Brayan
cd opencv
mkdir build
cd build
make -j$(nproc)
Alekhya
Thank you for accepting our solution. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
