Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1710 Discussions
Permission denied (publickey
jackschora
I tried all the method in this forums provide,
can not solve my problem.
u203142@devcloud: Permission denied (publickey).
ThasneemV_Intel
Good day to you!
Please refer the following link to troubleshoot the issue:
https://www.intel.com/content/www/us/en/developer/articles/technical/errors-setting-up-developer-cloud-for-oneapi.html#articleparagraph_1223631681
If the issue still persists, reconfigure SSH connection as per the documentation below:
Linux/macOS: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-linux-macos/
Windows: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-windows-openssh/
If the provided steps do not resolve the issue, please provide us with the following information:
1) SSH configuration file located in .ssh folder which can be found at the following directories:
Windows: C:\Users\<username>\.ssh\config
Linux: ~/. ssh/config
2) Are you using proxy or VPN? Kindly try connecting after disabling proxy or VPN.
3) Exact steps/commands that you are using to connect to DevCloud.
Thasneem Vazim
ThasneemV_Intel
We have not heard back from you. Could you please give us an update?
Thasneem Vazim
jackschora
i just give it up, and try to deploy locally
same problem in all my computer, many others meet but still not resolved by intel, its..
ThasneemV_Intel
Apologies for the inconvenience caused. In order to assist you better, can you get back to us with the following information:
1) Delete the known host file located in "C:\Users\<username>\.ssh\known_hosts" and try reconnecting.
2) Complete output obtained when running ssh -v devcloud.
Additionally, we have reached out to you through internal communication. Kindly respond to the same.
Thasneem Vazim
ThasneemV_Intel
We have not heard back from you. Could you please provide an update regarding the information we requested?
Thasneem Vazim
ThasneemV_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thasneem Vazim
