Intel® Tiber Developer Cloud
Help connecting to or getting started on Intel® Tiber Developer Cloud
how to stop VM instance
YogeshRajeyhraje
Hi
Let me know how to stop VM instance on intel developer cloud
Athirah_Intel
Hi YogeshRajeyhraje,
Unfortunately, we do not have the feature to stop a VM instance. Instead, you have to manually delete the instance.
Steps to manually delete an instance:
1)     From My instances, in main console, assure that your instance appears.
2)     Under Actions, select the Delete button.
3)     At the dialog “Delete instance”, select Delete to confirm your choice.
Athirah
Athirah_Intel
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Athirah
Ashwat
thanks, once you delete the instance, next time I want to use, do I need to recreate the whole thing OR is there an option to simply relaunch?
