Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
Conda Error: An error occurred while uninstalling package
pal__Ashwini1
I'm facing below error while running any command like install, update, uninstall
ERROR conda.core.link:_execute(700): An error occurred while uninstalling package '<unknown>::zeromq-4.2.3-2'.
Rolling back transaction: done
ValueError('Attempted to make prefix record for unknown package type: zeromq-4.2.3-2',)
Details about the environment:
OS: ubuntu 18.04
python version: intelpython3
It will be really helpful if someone can guide me on this.
JEYANTHKRI_N_Intel
Hi ,
Could you please provide the steps that you have performed for installing zeromg.
We are able to install zeromg without any errors using the below steps,
conda create -n env-name
conda install -c anaconda zeromq
pal__Ashwini1
Do I have to specifically create a new environment for installing zeromq or any other package?
The problem arises if I try to run commands like "conda update --all" or "conda install any_package". I don't remember installing zeromq, conda must have installed it as a dependency to some other package.
JEYANTHKRI_N_Intel
We are unable to create your issue from our end. To install packages, creating a new conda environment is recommended.
Could you please try reinstalling the conda environment and try the commands again.
Are you able to create a new conda environment without any errors?
Also are you getting the above mentioned error for the two commands only?
pal__Ashwini1
I used pip to install some packages. After going through this article[https://www.anaconda.com/using-pip-in-a-conda-environment/]I've reinstalled the anaconda whole package. I would like to close this issue. Thanks for the help.
Athira_C_Intel
Thank you for your confirmation. We are closing this case.
