6605 Discussions
Add OpenVino Toolkit inside an existent Docker container
Costa__Luís
Hello, I am trying to add the OpenVINO toolkit to a project which already has a container with all my dependencies.
I did everything according to the myriad of tutorials and explanations around but when try to load openvino into my jupyter notebook, I get the following error:
ImportError: libinference_engine.so: cannot open shared object file: No such file or directory
I added everything that I need to my PATH variable and if I print my `sys.path` in the notebook, I get this:
['/usr/lib/python36.zip', '/usr/lib/python3.6', '/usr/lib/python3.6/lib-dynload', '', '/root/.local/lib/python3.6/site-packages', '/code/src/project', '/usr/local/lib/python3.6/dist-packages', '/usr/local/lib/python3.6/dist-packages/pygpu-0.7.6-py3.6-linux-x86_64.egg', '/usr/local/lib/python3.6/dist-packages/Mako-1.1.0-py3.6.egg', '/usr/lib/python3/dist-packages', '/usr/local/lib/python3.6/dist-packages/IPython/extensions', '/root/.ipython', '/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer', '/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer', '/opt/intel/openvino_2020.2.120/data_processing/gstreamer/bin', '/opt/intel/openvino_2020.2.120/data_processing/gstreamer/bin/gstreamer-1.0', '/usr/local/nvidia/bin', '/usr/local/cuda/bin', '/usr/local/sbin', '/usr/local/bin', '/usr/sbin', '/usr/bin', '/sbin', '/bin', '/opt/intel/openvino_2020.2.120/python/python3.6', '/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer', '/opt/intel/openvino_2020.2.120/data_processing/gstreamer/bin', '/opt/intel/openvino_2020.2.120/data_processing/gstreamer/bin/gstreamer-1.0', '/usr/local/nvidia/bin', '/usr/local/cuda/bin', '/usr/local/sbin', '/usr/local/bin', '/usr/sbin', '/usr/bin', '/sbin', '/bin', '/opt/intel/openvino_2020.2.120/python/python3.6', '/opt/intel/openvino_2020.2.120/deployment_tools/model_optimizer', '/opt/intel/openvino_2020.2.120/data_processing/gstreamer/bin', '/opt/intel/openvino_2020.2.120/data_processing/gstreamer/bin/gstreamer-1.0', '/usr/local/nvidia/bin', '/usr/local/cuda/bin', '/usr/local/sbin', '/usr/local/bin', '/usr/sbin', '/usr/bin', '/sbin', '/bin', '/opt/intel/openvino_2020.2.120/python/python3.6']
Basically everything that `setupvars` does +  this path which onctains my openvino library: `'/opt/intel/openvino_2020.2.120/python/python3.6'`
Any idea what am I doing wrong?
Kind regards,
Luís
SIRIGIRI_V_Intel
Have you run the setupvars.sh before running the application. If you are running the application on Jupyter notebook, run setupvars.sh before opening the notebook. Refer the below command to run the setupvars.sh
source /opt/intel/openvino/bin/setupvars.sh
Ram prasad
