6572 Discussions
Argument element types are inconsistent
oltsym
My platform details: Ubuntu 18.04.5 LTS (Bionic Beaver), Openvino v2021.4.689
I would like to deploy darknet model  on NCS2 and I have converted .weights to tensorflow .pb format using this repo. After that I used model optimizer and converted tensorflow weights to IR using
python3 mo.py --framework=tf --data_type=FP16 --saved_model_dir /root/yolov4-416 --output_dir /root/IR --model_name yolov4 --input_shape=[1,608,608,3]
 As a result I got 3 files .bin .mapping .xml. But when I try to load it I got an error:
net = ie.read_network(model=model, weights=wights, init_from_buffer=False)
exec_net = ie.load_network(net, device_name=device, num_requests=2)
  File "detector.py", line 219, in <module>
    sys.exit(main() or 0)
  File "detector.py", line 81, in main
  File "ie_api.pyx", line 372, in openvino.inference_engine.ie_api.IECore.load_network
  File "ie_api.pyx", line 390, in openvino.inference_engine.ie_api.IECore.load_network
RuntimeError: Check 'element::Type::merge(inputs_et, inputs_et, get_input_element_type(i))' failed at core/src/op/concat.cpp:50:
While validating node 'v0::Concat StatefulPartitionedCall/functional_1/tf_op_layer_Shape_10/Shape_10 (DynDim/Gather_5760[0]:i64{1}, ConstDim/Constant_5761[0]:i32{1}) -> (i32{2})' with friendly_name 'StatefulPartitionedCall/functional_1/tf_op_layer_Shape_10/Shape_10':
Argument element types are inconsistent.
I would be really appreciate for help.
Thanx.
Wan_Intel
Hello Oltsym,
Thank you for reaching out to us and thank you for using Intel® Distribution of OpenVINO™ Toolkit!
I have downloaded yolov4.weights and converted it into .pb format using the command from this repo. However, I encountered an error: [ FRAMEWORK ERROR ] Cannot load input model: SavedModel format load failure when converting .pb file to IR file.
For your information, yolo-v4-tf, which is a Public Pre-Trained Model provided by Open Model Zoo, use the same yolov4.weights file and converted into IR using converter.py from Model Downloader.
I recommend you use the Model Downloader and other automation tools such as Model Downloader and Model Converter to download yolov4.weights and convert the model into Intermediate Representation.
Steps to download and convert yolo-v4-tf using Model Downloader and Model Converter are as follow:
cd <INSTALL_DIR>/deployment_tools/open_model_zoo/tools/downloader
python3 downloader.py --name yolo-v4-tf
python3 converter.py --name yolo-v4-tf
Default location of the IR file is located at the following directory:
<INSTALL_DIR>deployment_tools/open_model_zoo/tools/downloader/public/yolo-v4-tf
The inference result of running Object Detection C++ Demo with yolo-v4-tf using Intel® Neural Compute Stick 2 is shown as follows:
On another note, could you please share the following information with us for further investigation if the suggestion provided above does not resolve your issue?
·      Specific Darknet model
·      Demo application / scripts (detector.py)
Wan
Wan_Intel
Hi Oltsym,
Thanks for your question!
If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Wan
