Bug: setupvar.sh Error for 2021.1
Ray_Lo_Intel
I am getting this error when I run the setupvars.sh command in 2021.1 release in Mac OSX.
rlo@rlo-mac01 ~ % source /opt/intel/openvino_2021/bin/setupvars.sh
[setupvars.sh] ERROR: Can not find OpenVINO Python module for python3.7 by path /Users/python/python3.7
Ray_Lo_Intel
I think it has to do with this command, and now the workaround is to set BASE_DIR manually.
BASE_DIR="/opt/intel/openvino_2021"
https://docs.openvinotoolkit.org/2021.1/openvino_docs_install_guides_installing_openvino_macos.html#set-the-environment-variables
SCRIPT_DIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" >/dev/null 2>&1 && pwd )"
BASE_DIR="$( dirname "$SCRIPT_DIR" )"
Ray_Lo_Intel
IntelSupport
Community Manager
Hi Raymond,
We don't see the issue during the environment setup with OpenVINO 2021.1 even though the directory changed to /opt/intel/openvino_2021, but we glad that you are able to fix it now. Can you share which Python version you are using and how you installed it.
Aznie
IntelSupport
Community Manager
Hi Raymond,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Aznie
