- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I am using OpenVINO_2019_R1 to test/learn pedestrian detection and security barrier camera. Please find the system config
OS: Ubuntu 16.04
CPU: Intel® Core™ i3-8109U CPU @ 3.00GHz × 4
RAM:19.5 GiB
Can I use OpenVINO-model-server to deploy and test pedestrian detection and security barrier camera pre-trained models?
Guru
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Guru,
Yes, you should be able to. I would however recommend installing the latest version of OpenVINO R3
Sahira .
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Guru,
Sahira .
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Rizvi,
Thanks for the Quick response.
I tried to install R3, but I got an error(please find the attached screenshot), I couldn't figure out the reason for the error, that's the reason, I have uninstalled R3 and Installed R1.
Can you please let me know, if you could ascertain the problem.
Guru
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
My system config is as follows:
OS: Ubuntu 18.10
Processor:Intel® Core™ i3-8109U CPU @ 3.00GHz × 4
Memory:7.7 GiB
I downloaded the OpenVINO Version R3(openvino_2019.3.334)
While running installation scripts I got the Missing optional prerequisites error as in image 1
Then I ran the demo scripts for verifying installation
After running ./demo_squeezenet_download_convert_run.sh
in the cd /opt/intel/openvino/deployment_tools/demo path I got the error as in image2.
While building inference engine samples I used ./build_samples.sh in the /opt/intel/openvino/deployment_tools/inference_engine/samples/ directory I got the error as in image3.
Can you please clarify me whether the errors are related to Missing optional dependencies in installation process, If so how can I install the prerequisites.
If the errors occured during verification of the scripts, can you help me to solve the errors.
Thanks in advance.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Guru,
Did you try sudo apt-get -f install? Can you attach a screen shot of the output of that if it gives an error?
Best,
Sahira
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Rizvi,
We have successfully installed R3 in Ubuntu 18.04 and we are proceeding with OpenVINO model server
https://github.com/IntelAI/OpenVINO-model-server
Guru
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
