- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
i use ssd_inception_v2 pretrained model to train my own model.
i try to compile it with NCSDK2 and get an error above
File "/usr/local/bin/mvNCCompile", line 208, in <module>
args.old_parser, args.cpp, args)
File "/usr/local/bin/mvNCCompile", line 186, in create_graph
load_ret = load_network(args, parser, myriad_config)
File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 72, in load_network
parsedLayers = p.parse(arguments)
File "/usr/local/bin/ncsdk/Controllers/Parsers/TensorFlow.py", line 659, in parse
dummy_feed_dict = self._gen_dummy_feed_dict(arguments)
File "/usr/local/bin/ncsdk/Controllers/Parsers/TensorFlow.py", line 576, in _gen_dummy_feed_dict
feed_dict = {self.tf_input_op.outputs[0] : np.ones(self.get_input_shape(arguments))}
File "/usr/local/bin/ncsdk/Controllers/Parsers/TensorFlow.py", line 457, in get_input_shape
if inferred_input_shape[axis] != None:
IndexError: list index out of range
and than it is my config file i edit it refer this website https://movidius.github.io/ncsdk/tools/tf_ssd_config.html
input_height: 300
input_width: 300
postprocessing_params {
num_classes: 3
background_label_id: 0
max_detections: 10
nms_params {
score_threshold: 0.300000011921
iou_threshold: 0.600000023842
max_detections_per_class: 10
box_params {
var: 0.1
var: 0.1
var: 0.2
var: 0.2
score_converter: SIGMOID
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
i have finished my project already, thank for reply
i change mobile net pretrained models and finally compile it and run it correctly,😊
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi CChiH13,
Thanks for reaching out. To help you, could you please answer some question that we have for you:
Which version of the Intel® Movidius™ NCSDK are you using?
What Operative System do you have?
Can you share with us your model?
Which is the command that you used to compile your model?
On the other hand, the Intel® Movidius™ NCSDK is no longer being maintained, so, we recommend you migrate to the OpenVINO™ toolkit.
Javier A.
A Contingent Worker at Intel
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
NCSDK verison:2.10.01.01
i have Ubuntu16.04,Ubuntu18.04,Windows10,Raspbian Stretch
i use command as below
mvNCCompile frozen_inference_graph.pb --tf-ssd-config ssd_inception.config
models is uploading, i will post it as soon as possible
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
model:https://drive.google.com/file/d/1796s3I9FmqSDrhpBVueaTh2jXRA5F50A/view?usp=sharing
demo file contain an python code and two image , it can run in ubuntu normally
demo:https://drive.google.com/file/d/19qJGad1G2ONkazHDmS9gWg5PBx9DToIr/view?usp=sharing
thank for your help
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
item {
item {
item {
Here is the content about "object_detection.pbtxt" i forgot pack it into the zip file
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi CChiH13,
Thank you for your response. We are trying to replicate your issue from our end, but we are getting a different error. We think it is because we are using a different version of TensorFlow, could you please answer some questions that we have for you:
Which TensorFlow version did you use to train your network?
Which TensorFlow version are you using with the NCSDK?
By the way, is there any reason to continue using the Intel® Movidius™ NCSDK and not migrate to OpenVINO™ toolkit?
Javier A.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi CChiH13,
I'm glad you were able to get it to work! Feel free to reach out again if you have additional questions.
Jesus
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
