6577 Discussions
Confidence score on custom classify model
hungtrieu07
In the previous thread, I have successfully display the output of person attribute recognition model using DLStreamer pipeline. But when debug, I saw the confidence score of that model is only 1 value, but I need each value of each attribute, for more post-processing on gvapython element.
This is my current pipeline:
GST_DEBUG=4 gst-launch-1.0 filesrc location=../video_data/1740731094984.mp4 ! decodebin ! videoconvert ! \
gvadetect model=./ov_exported_model/person_vehicle/FP16.xml device=CPU ! queue ! \
gvaclassify model=./onnx_models/openvino_model/model.xml model-proc=./onnx_models/openvino_model/model-proc.json object-class="person" device=CPU ! queue ! \
gvapython module=./process_attributes.py ! queue ! \
gvawatermark ! videoconvert ! autovideosink sync=false
hungtrieu07
Hello Witold, I tried your solution and this is the result:
Now the output label is only from detection model, the person attribute output are gone. I'm doing on merge some attributes into a group, I have some groups named "head region", "upper body region", etc... I have total 9 groups, each group I will get the max confidence score, so no more case a person maybe have 2 colors on upper body region. This is a graph of model's output:
Witold_Intel
Hi Hung, thanks for pointing this out. Apparently, an additional script for attribute grouping will be needed. It can be called attribute_grouper.py and look like this:
import numpy as np
# Full attribute list in EXACT model output order (verify with benchmark_app)
ATTRIBUTES_LIST = [
  "accessoryHat",    # 0
  "hairLong",      # 1
  "hairShort",     # 2
  "upperBodyShortSleeve", # 3
  "upperBodyBlack",   # 4
  "upperBodyBlue",   # 5
  "upperBodyBrown",   # 6
  "upperBodyGreen",   # 7
  "upperBodyGrey",   # 8
  "upperBodyOrange",  # 9
  "upperBodyPink",   # 10
  "upperBodyPurple",  # 11
  "upperBodyRed",    # 12
  "upperBodyWhite",   # 13
  "upperBodyYellow",  # 14
  "upperBodyLongSleeve", # 15
  "lowerBodyShorts",  # 16
  "lowerBodyShortSkirt", # 17
  "lowerBodyBlack",   # 18
  "lowerBodyBlue",   # 19
  "lowerBodyBrown",   # 20
  "lowerBodyGreen",   # 21
  "lowerBodyGrey",   # 22
  "lowerBodyOrange",  # 23
  "lowerBodyPink",   # 24
  "lowerBodyPurple",  # 25
  "lowerBodyRed",    # 26
  "lowerBodyWhite",   # 27
  "lowerBodyYellow",  # 28
  "lowerBodyLongSkirt", # 29
  "footwearLeatherShoes", # 30
  "footwearSandals",  # 31
  "footwearShoes",   # 32
  "footwearSneaker",  # 33
  "carryingBackpack",  # 34
  "carryingMessengerBag", # 35
  "carryingLuggageCase", # 36
  "carryingSuitcase",  # 37
  "personalLess30",   # 38
  "personalLess45",   # 39
  "personalLess60",   # 40
  "personalLarger60",  # 41
  "personalLess15",   # 42
  "personalMale",    # 43
  "personalFemale"   # 44
# Configure your 9 attribute groups here
ATTRIBUTE_GROUPS = {
  # Group 1: Head Attributes
  "Head": {
    "attributes": ["accessoryHat", "hairLong", "hairShort"],
    "display_template": "Head: {attribute}",
    "threshold": 0.4 # Lower threshold for head items
  # Group 2: Upper Body Color
  "UpperColor": {
    "attributes": ["upperBodyBlack", "upperBodyBlue", "upperBodyBrown",
           "upperBodyGreen", "upperBodyGrey", "upperBodyOrange",
           "upperBodyPink", "upperBodyPurple", "upperBodyRed",
           "upperBodyWhite", "upperBodyYellow"],
    "display_template": "Upper: {attribute}",
    "threshold": 0.5
  # Group 3: Upper Body Style
  "UpperStyle": {
    "attributes": ["upperBodyShortSleeve", "upperBodyLongSleeve"],
    "display_template": "Sleeve: {attribute}",
    "threshold": 0.5,
    "mutually_exclusive": True # Only one can be true
  # Group 4: Lower Body Color
  "LowerColor": {
    "attributes": ["lowerBodyBlack", "lowerBodyBlue", "lowerBodyBrown",
           "lowerBodyGreen", "lowerBodyGrey", "lowerBodyOrange",
           "lowerBodyPink", "lowerBodyPurple", "lowerBodyRed",
           "lowerBodyWhite", "lowerBodyYellow"],
    "display_template": "Lower: {attribute}",
    "threshold": 0.5
  # Group 5: Lower Body Style
  "LowerStyle": {
    "attributes": ["lowerBodyShorts", "lowerBodyShortSkirt", "lowerBodyLongSkirt"],
    "display_template": "Bottom: {attribute}",
    "threshold": 0.5,
  # Group 6: Footwear
  "Footwear": {
    "attributes": ["footwearLeatherShoes", "footwearSandals",
           "footwearShoes", "footwearSneaker"],
    "display_template": "Shoes: {attribute}",
    "threshold": 0.5
  # Group 7: Carrying Items
  "Carrying": {
    "attributes": ["carryingBackpack", "carryingMessengerBag",
           "carryingLuggageCase", "carryingSuitcase"],
    "display_template": "Bag: {attribute}",
    "threshold": 0.4 # Lower threshold for rare items
  # Group 8: Age Group
  "Age": {
    "attributes": ["personalLess15", "personalLess30",
           "personalLess45", "personalLess60", "personalLarger60"],
    "display_template": "Age: {attribute}",
    "threshold": 0.5,
  # Group 9: Gender
  "Gender": {
    "attributes": ["personalMale", "personalFemale"],
    "display_template": "Gender: {attribute}",
    "threshold": 0.7, # Higher threshold for gender
def process_frame(frame):
  for roi in frame.regions():
    # 1. Extract raw predictions
    attr_predictions = {}
    for tensor in roi.tensors():
      if tensor.format() == "ANY":
        data = tensor.data()
        if len(data) == len(ATTRIBUTES_LIST):
          for i, confidence in enumerate(data):
            attr_predictions[ATTRIBUTES_LIST[i]] = float(confidence)
    # 2. Process each group
    results = []
    for group_name, config in ATTRIBUTE_GROUPS.items():
      best_attr = None
      max_conf = 0
      for attribute in config["attributes"]:
        conf = attr_predictions.get(attribute, 0)
        # Skip if mutually exclusive and we already have a high-confidence result
        if config.get("mutually_exclusive", False) and best_attr and max_conf > config["threshold"]:
          continue
        if conf > max_conf and conf > config["threshold"]:
          max_conf = conf
          best_attr = attribute
      if best_attr:
        display_text = config["display_template"].format(attribute=best_attr)
        results.append((display_text, max_conf))
    # 3. Update ROI labels (shows all groups with detected attributes)
    if results:
      # Combine all results into one label for cleaner display
      combined_label = " | ".join([text for text, _ in results])
      roi.set_label(combined_label, min([conf for _, conf in results]))
  return True
# For debugging (enable in development)
DEBUG_MODE = False
if DEBUG_MODE:
  def debug_print_predictions(predictions):
    print("\nRaw Predictions:")
    for attr, conf in predictions.items():
      if conf > 0.3: # Only show attributes with >30% confidence
        print(f"{attr}: {conf:.2f}")
  # Add this inside process_frame after getting attr_predictions
  debug_print_predictions(attr_predictions)
Witold_Intel
I can add that the updated pipeline should be set up like this if it helps you:
gst-launch-1.0 \
filesrc location=video.mp4 ! decodebin ! videoconvert ! \
gvadetect model=person_vehicle.xml device=CPU ! queue ! \
gvainference model=attribute_model.xml device=CPU inference-region=roi ! queue ! \
gvapython module=attribute_grouper.py ! \
Witold_Intel
Hi Hung, please respond to the previous messages within 3 business days. Otherwise I will consider this issue resolved.
Wan_Intel
Hi hungtrieu07,
Thank you for your question.
If you need additional information from Intel, please submit a new thread as this thread will no longer be monitored.
Wan
