6573 Discussions
Conversion of onnx model with legacy IR version
MicheleBolognini
I am trying to convert a model from .onnx format into OpenVINO, for use with an old software framework.
I know the Model Optimizer should be used for this, but if I try
mo --input_model model.onnx
then the new model gets generated with IR version 11. Unfortunately, my old framework does not support newer IR versions. Is there a way of forcing the conversion with an older IR version?
Labels (2)
Hairul_Intel
Hi MicheleBolognini,
For your information, OpenVINO™ Toolkit 2022.1 release does provide backward compatibility support for reading IR v10 model. However, it is not possible to convert model into older IR v10 using the new OpenVINO™ Toolkit 2022.1 release.
In order to convert a model into legacy IR v10 model, you'd need to use Model Optimizer from OpenVINO™ Toolkit 2021.4.2 release. You can follow the guide on Converting a ONNX* Model for further information.
Here is the result for converting a resnet50 ONNX model into IR v10 model using OpenVINO™ Toolkit 2021.4.2:
Hairul
MicheleBolognini
Thank you @Hairul_Intel for the clarification.
I noticed that, though I had installed the 2020.3 Release, the Model Optimizer version was 2022.1.something, probably a carryover from a previous installation.
I will thoroughly clean up the installed version and make sure I install and older release before I try again.
Michele
Hairul_Intel
Hi Michele,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Hairul
