6573 Discussions
Could able to run demo sound classification application in openvino
SA8
To run sound classication demo in openvino, I have followed below steps:
  1. cd /opt/intel/openvino_2021/install_dependencies
  2. sudo -E ./install_openvino_dependencies.sh
  3. for env setting: source /opt/intel/openvino_2021/bin/setupvars.sh
  4. cd /opt/intel/openvino_2021/deployment_tools/model_optimizer/install_prerequisites
  5. sudo ./install_prerequisites.sh
  6. git clone https://github.com/openvinotoolkit/open_model_zoo.git. Then I placed the cloned repo in the deployment_tools directory.
  7. sudo python3 /opt/intel/openvino_2021/deployment_tools/open_model_zoo/tools/downloader/downloader.py --name aclnet
  8. sudo python3 /opt/intel/openvino_2021/deployment_tools/open_model_zoo/tools/downloader/converter.py --name aclnet
Here I got error:
/usr/lib/python3/dist-packages/requests/__init__.py:89: RequestsDependencyWarning: urllib3 (1.26.4) or chardet (3.0.4) doesn't match a supported version!
  warnings.warn("urllib3 ({}) or chardet ({}) doesn't match a supported "
Unable to locate Model Optimizer. Use --mo or run setupvars.sh/setupvars.bat from the OpenVINO toolkit.
Here aclent model downloaded and gives .onnx in public folder. now how to convert .onnx file to ir format(xml and bin format)?
I followed below coomand too but still I get same error
sudo python3 ./mo.py --input_model ~/public/aclnet/aclnet_des_53.onnx --output_dir ~/public/aclnet
https://docs.openvinotoolkit.org/latest/omz_demos_sound_classification_demo_python.html
Please can anyone help on this?
Syamimi_Intel
Hi Swagatika Achariya,
Thank you for reaching out. For your information, you are getting this error because the script attempts to locate Model Optimizer using the environment variables set by the OpenVINO™ toolkit's setupvars.sh/setupvars.bat script.
As such, you can override this heuristic with the --mo option:
python3 converter.py --mo my/openvino/path/model_optimizer/mo.py --name aclnet
Syamimi
SA8
Hi Syamimi,
Thanks a lot for your reply. I could able to do it.
Thanks & Regards,
Swagatika
Syamimi_Intel
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Syamimi
