6577 Discussions
Docker Openvino c++ compiled code throws bad allocation
ashleysmart
I downloaded the current windows docker distrubtion of the openvino toolkit and then using choco installed MSBuild, and cmake(and a few other parts like gtest and boost). Once done I created a basic cmake file with some tests ie:
#pragma warning(push, 0)
#include <inference_engine.hpp>
#include <opencv2/opencv.hpp>
#pragma warning(pop)
#include <gtest/gtest.h>
TEST(ThirdParty, OpenCVIsAlive)
    std::string opencvInfo =
        cv::getBuildInformation();
    ASSERT_TRUE(opencvInfo.size() > 0);
TEST(ThirdParty, InferenceEngineIsAlive)
    EXPECT_NO_THROW({
            InferenceEngine::Core core;
Much to my alarm the 'InferenceEngine::Core core;' line actually throws a "bad alloaction" execption and the 'cv::getBuildInformation();' aborts(i think)..
Can anyone explain what i have done wrong? It seems i cant build and link c++ againest the docker installed openvino toolkit??
Thanks in advance,
Ash
ashleysmart
For more background: my cmakelist.txt links the opencv and inference engine etc using these lines
set(INTEL_OPENVINO_DIR $ENV{INTEL_OPENVINO_DIR})
set(ngraph_DIR ${INTEL_OPENVINO_DIR}\\deployment_tools\\ngraph\\cmake)
set(InferenceEngine_DIR ${INTEL_OPENVINO_DIR}\\deployment_tools\\inference_engine\\share)
set(TBB_DIR ${INTEL_OPENVINO_DIR}\\windows\\inference_engine\\external\\tbb\\cmake)
set(OpenCV_DIR ${INTEL_OPENVINO_DIR}\\opencv\\cmake)
Iffa_Intel
I did a quick check to verify the OpenVINO IECore import inside the docker.
If everything had been set up properly, it should work without any error prompted (whether in C++ or Python).
You may refer to my attachments.
Any chance that you forgot to run the setupvars.bat?. This initialization script is the one that would link the OpenVINO libraries altogether.
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
