Dose openvino IR support multi-shape images as input ?
D__eric
I got an error when i was try to convert a Fully Convolutional Network without fix the input images size, so i was wondering if IR support  multi-shape images as input during inference process。
A resized image as the input is not the way i want,how can i convert a FCN like network to openvino IR?
Roy_A_Intel
Hi Eric
You can specify an arbitrary input size as required, then during the inferencing to work with multi-shape images, use the shape inference feature of the inference engine to work with differently-sized inputs. More on shape inference is available here  https://docs.openvinotoolkit.org/latest/_docs_IE_DG_ShapeInference.html
Roy
Roy_A_Intel
Hi Eric
Roy
