Dynamic batch size
Murugappan__Indrajit
Hi
In OpenVINO R3, I can see that there is an option to change the batch size dynamically (C++). This can be done just before loading the network into the plugin.
if (enable_dynamic_batch)
    config[PluginConfigParams::KEY_DYN_BATCH_ENABLED] = PluginConfigParams::YES;
I want to know if there is any similar functionality available in Python API. Could you please let me know the correct way to do it in python?
Indrajit
Mark_L_Intel1
Hi Indrajit,
It looks like we should have, if you see the following document:
Plugin load method, we do have a config dictionary as an input parameters. I would expect this should include the parameter you need.
I check the python sample and other document and I didn't find it. So let me check internally.
Mark
Hi Mark
I tried setting it in my python script like this:
exec_net = plugin.load(network=net,config={'KEY_DYN_BATCH_ENABLED':'YES'})
But I got the following error:
RuntimeError: [NOT_FOUND] Unsupported property KEY_DYN_BATCH_ENABLED by CPU plugin
I want to know if that is the correct way to set it in python.
Indrajit
Mikhail_T_Intel
Hi Indrajit,
To set this config property for the plugin please pass the key without 'KEY_' prefix like this
exec_net = plugin.load(network=net, config={'DYN_BATCH_ENABLED':'YES'})
Other option to change batch size is to use batch_size property of the IENetwork instance or use reshape function (which is preferable in some cases like object detection networks) before loading network to the plugin:
# Setting batch using batch_size
net.batch_size = 8
# Setting batch using reshape
example_shape = (8, 3, 224, 224)
net.reshape({"input_layer_name" : example_shape})
Mikhail
Hi Mikhail
Thanks for your response. Now there is no issue loading the network into the plugin.
For my application, I would load the model once and run inference multiple times with different batch size each time. So I want to be able to change the batch size after the loading the network to the plugin.
With your suggestion I'm able to load the network without any issue but I get the this error when I send a batch of 2 images instead of one:
ValueError: could not broadcast input array from shape (2,3,72,72) into shape (1,3,72,72)
Shouldn't the config property "'DYN_BATCH_ENABLED':'YES'" allow the network to accept images of any batch size?
Please clarify on this.
Indrajit
Mark_L_Intel1
Hi Mikhail,
Do we have a document to describe the Python API?
This is the only document I found:
https://software.intel.com/en-us/articles/OpenVINO-InferEngine
Mark
Caspi__Itai
Was the 'DYN_BATCH_ENABLED' config name changed in R5?
Using the code described above I now get the following error when using MYRIAD:
RuntimeError: [NOT_FOUND] DYN_BATCH_ENABLED key does not exist
Nikolay_L_Intel1
Hi, Itai!
Myriad doesn't support dynamic batch. It's supported by CPU and GPU plugins.
Caspi__Itai
Got it. Thanks Nikolay!
Lechatellier__Brice1
Running into the same issue as original poster, how do you enable dynamic batching in 2019_R2 please?
I've tried to set `config={'DYN_BATCH_ENABLED':'YES'}` when loading the network but getting an error "ValueError: could not broadcast input array from shape (2,3,227,227) into shape (1,3,227,227)"
