[ ERROR ] [VPU] Unsupported activation type while running SSDMobilenet using OpenVino Inference Engine
Moosa__Azmath
I downloaded tensorflow's `ssd_mobilenet_v1_coco` and converted it to Intermediate Representation file using
/opt/intel/computer_vision_sdk_2018.2.300/deployment_tools/model_optimizer$ python3 mo_tf.py --input_model=/work/22_movidus/ncappzoo/tensorflow/custom_tf/ssdmobilenet_frozen_inference_graph.pb --tensorflow_use_custom_operations_config extensions/front/tf/ssd_support.json --output="detection_boxes,detection_scores,num_detections" --data_type FP16
It generated xml and bin files.  I then tried to use it in movidius but I am getting this error
/opt/intel/computer_vision_sdk_2018.2.300/deployment_tools/demo$ ../inference_engine/samples/build/intel64/Release/object_detection_demo_ssd_async -d "MYRIAD"  -m ./ir/ssdmobilenet16/ssdmobilenet_frozen_inference_graph.xml -i /dev/video0
InferenceEngine:
	API version ............ 1.1
	Build .................. 11653
[ INFO ] Parsing input parameters
[ INFO ] Reading input
[ INFO ] Loading plugin
	Description ....... myriadPlugin
[ INFO ] Loading network files
[ INFO ] Batch size is forced to  1.
[ INFO ] Checking that the inputs are as the sample expects
[ INFO ] Checking that the outputs are as the sample expects
[ INFO ] Loading model to the plugin
I have read that people are able to run this network on the NCS.  But No luck for me so far...  I would be grateful if anyone could help.
Severine_H_Intel
Hi Azmath,
I could reproduce your error. I will investigate with our dev team the problem.
Best,
Severine
ELUMALAI__BALAJI
Habert, Severine (Intel) wrote:
If you resolved the issue as Azmath discussed please remind the link and updates
ELUMALAI__BALAJI
I had the same issue happend while using coco2018, but using coco2017 generated to .xml is running good.
ELUMALAI__BALAJI
Hi Severine,
    Please remind me updates if this [ ERROR ] [VPU] Unsupported activation type while running SSDMobilenet using OpenVino Inference Engine problem is solved, If there is any alternatives suggest if possible.
VnsMurthy_S_Intel
I am getting the same problem is there any solution available for this?
