6574 Diskussionen
Error: No nodes replied within time constraint
raushan
Anfänger
2.980Aufrufe
I was trying to launch Dl workbench for Openvino 2021 and getting above error. These are the steps i followed:
1.sudo docker pull openvino/workbench
2.sudo docker run -p 127.0.0.1:5665:5665 --name workbench -it openvino/workbench
the above command doesn't provide any url for Dl workbench, but the Error: No nodes replied within time constraint .I have attached the logs also.
Beschriftungen (1)
2 Antworten
Iffa_Intel
2.956Aufrufe
Greetings,
First and foremost, it is important to emphasize that only Ubuntu* 18.04 linux distribution is validated.
You may refer to here, where a video is provided: https://docs.openvinotoolkit.org/latest/workbench_docs_Workbench_DG_Install_from_Docker_Hub.html
Specific for Linux, you can refer here for more details:
https://docs.openvinotoolkit.org/latest/workbench_docs_Workbench_DG_Install_from_DockerHub_Linux.html
Generally you need to:
  1.  install Docker CE for Linux first.
  2. from a terminal: wget https://raw.githubusercontent.com/openvinotoolkit/workbench_aux/master/start_workbench.sh && bash start_workbench.sh
  3. wget https://raw.githubusercontent.com/openvinotoolkit/workbench_aux/master/start_workbench.sh
  4. chmod +x start_workbench.sh
  5. ./start_workbench.sh -IMAGE_NAME openvino/workbench
  6. Once the http://127.0.0.1:5665 link followed by a generated token appears in the console log, open it in your browser. See Enter DL Workbench for details.
If you have permission issues do this:
Permission Issue fix: https://www.digitalocean.com/community/questions/how-to-fix-docker-got-permission-denied-while-trying-to-connect-to-the-docker-daemon-socket
then run
Sincerely,
Iffa
Iffa_Intel
2.928Aufrufe
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question
Sincerely,
Iffa
Antworten
