Error compiling network
I'm trying to convert a Caffe network with AbsVal layer but getting an error.
Network git at: https://github.com/guozhongluo/head-pose-estimation-and-face-landmark
Can someone please advice ?
Tsahi.
@tsahim I can't see AbsVal layer in this project as well as weight (.caffemodel file). Please explain how do you manage to convert this network for NCS so we can triage the problem.
Wrong link sorry,
this is the library at: https://github.com/jiangwqcooler/face-landmark
and this is the orig proto.txt (before shape mod ):
input: "data"
input_dim: 1
input_dim: 1
input_dim: 60
input_dim: 60
the actual net
layer 1
layer {
type: "Convolution"
bottom: "data"
top: "Conv1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 20
pad: 2
kernel_size: 5
stride: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
bottom: "Conv1"
top: "ActivationTangH1"
type: "TanH"
layer {
bottom: "ActivationTangH1"
top: "Abs1"
type: "AbsVal"
layer {
type: "Pooling"
bottom: "Abs1"
top: "Pool1"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "Convolution"
bottom: "Pool1"
top: "Conv2"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 48
pad: 2
kernel_size: 5
stride: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
bottom: "Conv2"
top: "ActivationTangH2"
type: "TanH"
layer {
bottom: "ActivationTangH2"
top: "Abs2"
type: "AbsVal"
layer {
type: "Pooling"
bottom: "Abs2"
top: "Pool2"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer 3
layer {
type: "Convolution"
bottom: "Pool2"
top: "Conv3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 64
pad: 0
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
bottom: "Conv3"
top: "ActivationTangH3"
type: "TanH"
layer {
bottom: "ActivationTangH3"
top: "Abs3"
type: "AbsVal"
layer {
type: "Pooling"
bottom: "Abs3"
top: "Pool3"
pooling_param {
pool: MAX
kernel_size: 3
stride: 2
layer 4
layer {
type: "Convolution"
bottom: "Pool3"
top: "Conv4"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
convolution_param {
num_output: 80
pad: 0
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
std: 0.1
bias_filler {
type: "constant"
value: 0.2
layer {
bottom: "Conv4"
top: "ActivationTangH4"
type: "TanH"
layer {
bottom: "ActivationTangH4"
top: "Abs4"
type: "AbsVal"
layer {
type: "InnerProduct"
bottom: "Abs4"
top: "Dense1"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
inner_product_param {
num_output: 512
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
layer {
bottom: "Dense1"
top: "ActivationTangH5"
type: "TanH"
layer {
bottom: "ActivationTangH5"
top: "Abs5"
type: "AbsVal"
layer {
bottom: "Abs5"
top: "Dense3"
param {
lr_mult: 1
decay_mult: 1
param {
lr_mult: 2
decay_mult: 0
num_output: 136
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0
@tsahim I believe that we may not yet support the Absolute Value layer. Can you post the error that you are receiving?
