- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Everyone
I am trying to convert frozen tensoflow model to IR and getting following error
Cannot infer shapes or values for node "detector/yolo-v3/strided_slice".
strided_slice node is created in tensorflow by the line
inputs = inputs[:, 2:-2, 2:-2, :]
What am i missing ?
Yatish
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Yatish,
If the input dimensions are in that format MO cannot interpret them for that node. Can you send the full log of the error from MO?
Kind Regards,
Monique Jones
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
After modifying my tensorflow model to folowing
test = inputs.shape # trim back to desired size inputs = inputs[:, 2:test[1]-2, 2:test[2]-2, :]
i moved forward with the conversion, but it still failed with following error message
[ 2018-07-09 12:49:46,680 ] [ ERROR ] [ main:230 ] -------------------------------------------------
[ 2018-07-09 12:49:46,680 ] [ ERROR ] [ main:231 ] ----------------- INTERNAL ERROR ----------------
[ 2018-07-09 12:49:46,680 ] [ ERROR ] [ main:232 ] Unexpected exception happened.
[ 2018-07-09 12:49:46,680 ] [ ERROR ] [ main:233 ] Please contact Model Optimizer developers and forward the following information:
[ 2018-07-09 12:49:46,680 ] [ ERROR ] [ main:234 ] The truth value of an array with more than one element is ambiguous. Use a.any() or a.all()
[ 2018-07-09 12:49:46,680 ] [ ERROR ] [ main:235 ] Traceback (most recent call last):
File "/opt/intel/computer_vision_sdk_fpga_2018.1.267/deployment_tools/model_optimizer/mo/main.py", line 222, in main
return driver(argv)
File "/opt/intel/computer_vision_sdk_fpga_2018.1.267/deployment_tools/model_optimizer/mo/main.py", line 190, in driver
mean_scale_values=mean_scale)
File "/opt/intel/computer_vision_sdk_fpga_2018.1.267/deployment_tools/model_optimizer/mo/pipeline/tf.py", line 182, in tf2nx
fuse_mul_add_sequence(graph)
File "/opt/intel/computer_vision_sdk_fpga_2018.1.267/deployment_tools/model_optimizer/mo/middle/passes/fusing.py", line 452, in fuse_mul_add_sequence
is_fused = fuse_linear_sequence(graph, node)
File "/opt/intel/computer_vision_sdk_fpga_2018.1.267/deployment_tools/model_optimizer/mo/middle/passes/fusing.py", line 405, in fuse_linear_sequence
if any([x != 0 for x in add]) and any([x != 1 for x in mul]):
ValueError: The truth value of an array with more than one element is ambiguous. Use a.any() or a.all()
I have attached logfile with the comment.
Yatish
