6594 Discussions
Error in running the OpenVino Image Classification Sample
Tithi
Hello!
This is in response to my previous question on the same code. On running the code in the command prompt, I am getting a new error which I am attaching here as a screenshot. Kindly help:
Thank you!
Tithi
@Hairul_Intel could you please help!
Hairul_Intel
Hi Tithi,
I've encountered the same error message when providing incorrect path or missing image for the "-i" command when running the sample. Here is the error message:
Please provide the correct path for your image and ensure it is available in your directory. Here is my sample directory and the result for running the sample with the image:
Hairul
Tithi
Hello Hairul!
I have the image in the same directory itself, but I am still getting the same error. Here is the a snapshot of the directory.Capture.PNG
Tithi
Hairul_Intel
Hi Tithi,
From my end, I was able to replicate this issue by using an empty image as an input and received the following errors:
On another note, you can verify whether OpenCV was able to read your image by accessing the image properties. To print the image properties, run the following command in a Python shell:
import cv2
image = cv2.imread("banana.jpg")
print(image.shape)
Here is the result of a valid image:
I'd suggest you to have a try using different test images from the media files collection available at
https://storage.openvinotoolkit.org/data/test_data/images/
Additionally, please do share your image files with us for further investigation regarding this issue.
Hairul
Hairul_Intel
Hi Tithi,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Hairul
