Error on creating IR for Tensorflow Object Detection
Kaliyappan__Malathi
I'm using  Ubuntu18.04, Intel® Core™ i3-8109U CPU @ 3.00GHz × 4.
My OpenVINO version is R3 (openvino_2019.3.376).
I tried to Create IR for Tensorflow Object Detection model. I'm using faster_rcnn_inception_v2_coco_2018_01_28. I follow this link http://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_Object_Detection_API_Models.html
While I run
sudo python3 mo_tf.py  --input_model=/home/ioz/AWS/Helmet_Project/research/object_detection/vehicle_inference_graph/frozen_inference_graph.pb --tensorflow_use_custom_operations_config /opt/intel/openvino/deployment_tools/model_optimizer/extensions/front/tf/faster_rcnn_support.json  --tensorflow_object_detection_api_pipeline_config /home/ioz/AWS/Helmet_Project/research/object_detection/training/pipeline.config --reverse_input_channels
I got this error
[ ERROR ]  Failed to match nodes from custom replacement description with id 'ObjectDetectionAPIProposalReplacement':
It means model and custom replacement description are incompatible.
Try to correct custom replacement description according to documentation with respect to model node names
[ ERROR ]  Found the following nodes '[]' with name 'crop_proposals' but there should be exactly 1. Looks like ObjectDetectionAPIProposalReplacement replacement didn't work.
Exception occurred during running replacer "ObjectDetectionAPIDetectionOutputReplacement" (<class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIDetectionOutputReplacement'>): Found the following nodes '[]' with name 'crop_proposals' but there should be exactly 1. Looks like ObjectDetectionAPIProposalReplacement replacement didn't work.
I tried changing .json files(faster_rcnn_support_api_v1.7.json, faster_rcnn_support_api_v1.10.json, faster_rcnn_support_api_v1.13.json, faster_rcnn_support_api_v1.14.json) but the error was same.
Can you please help me to solve this.
Thanks in Advance.
JesusE_Intel
Hi Malathi,
The development team took a look at your model and found that there are several significant differences with the original model. It would not be an easy task to enable it. We do have a guide to train a faster-rcnn to detect fruits, could you try to follow the guide with your objects and retrain?
https://software.intel.com/en-us/articles/fruit-classification-prototype
I walked though the guide and it worked for me, I used OpenVINO 2019 R3.1 to deploy and the included Tensorflow 1.14 version to train the network.
Jesus
JesusE_Intel
Hi Kaliyappan, Malathi,
I successfully converted the faster_rcnn_inception_v2_coco_2018_01_28 using the following command:
python3 ~/intel/openvino/deployment_tools/model_optimizer/mo_tf.py \
--input_model frozen_inference_graph.pb \
--tensorflow_use_custom_operations_config ~/intel/openvino/deployment_tools/model_optimizer/extensions/front/tf/faster_rcnn_support.json \
--tensorflow_object_detection_api_pipeline_config pipeline.config \
--reverse_input_channels \
--batch 1
 I used the faster_rcnn_support.json from OpenVINO, and the pipeline.config included in the link above. Could you give it a try and let me know if it works for you? I am also using Ubuntu 18.04 with the latest OpenVINO package (2019.3.376).
Jesus
Kaliyappan__Malathi
Hi Jesus E, Thanks for your reply.
I tried the command you gave,
python3 /opt/intel/openvino/deployment_tools/model_optimizer/mo_tf.py  --input_model frozen_inference_graph.pb  --tensorflow_use_custom_operations_config /opt/intel/openvino/deployment_tools/model_optimizer/extensions/front/tf/faster_rcnn_support.json  --tensorflow_object_detection_api_pipeline_config /home/ioz/AWS/Helmet_Project/research/object_detection/training/pipeline.config  --reverse_input_channels  --batch 1
But still got the same error
Model Optimizer arguments:
Common parameters:
	- Path to the Input Model: 	/home/ioz/AWS/Helmet_Project/research/object_detection/vehicle_inference_graph/frozen_inference_graph.pb
	- Path for generated IR: 	/home/ioz/AWS/Helmet_Project/research/object_detection/vehicle_inference_graph/.
	- IR output name: 	frozen_inference_graph
	- Log level: 	ERROR
	- Batch: 	1
	- Input layers: 	Not specified, inherited from the model
	- Output layers: 	Not specified, inherited from the model
	- Input shapes: 	Not specified, inherited from the model
	- Mean values: 	Not specified
	- Scale values: 	Not specified
	- Scale factor: 	Not specified
	- Precision of IR: 	FP32
	- Enable fusing: 	True
	- Enable grouped convolutions fusing: 	True
	- Move mean values to preprocess section: 	False
	- Reverse input channels: 	True
TensorFlow specific parameters:
	- Input model in text protobuf format: 	False
	- Path to model dump for TensorBoard: 	None
	- List of shared libraries with TensorFlow custom layers implementation: 	None
	- Update the configuration file with input/output node names: 	None
	- Use configuration file used to generate the model with Object Detection API: 	/home/ioz/AWS/Helmet_Project/research/object_detection/training/pipeline.config
	- Operations to offload: 	None
	- Patterns to offload: 	None
	- Use the config file: 	/opt/intel/openvino/deployment_tools/model_optimizer/extensions/front/tf/faster_rcnn_support.json
Model Optimizer version: 	2019.3.0-408-gac8584cb7
/home/ioz/.local/lib/python3.6/site-packages/tensorflow/python/framework/dtypes.py:516: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_qint8 = np.dtype([("qint8", np.int8, 1)])
/home/ioz/.local/lib/python3.6/site-packages/tensorflow/python/framework/dtypes.py:517: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_quint8 = np.dtype([("quint8", np.uint8, 1)])
/home/ioz/.local/lib/python3.6/site-packages/tensorflow/python/framework/dtypes.py:518: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_qint16 = np.dtype([("qint16", np.int16, 1)])
/home/ioz/.local/lib/python3.6/site-packages/tensorflow/python/framework/dtypes.py:519: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_quint16 = np.dtype([("quint16", np.uint16, 1)])
/home/ioz/.local/lib/python3.6/site-packages/tensorflow/python/framework/dtypes.py:520: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_qint32 = np.dtype([("qint32", np.int32, 1)])
/home/ioz/.local/lib/python3.6/site-packages/tensorflow/python/framework/dtypes.py:525: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  np_resource = np.dtype([("resource", np.ubyte, 1)])
/home/ioz/.local/lib/python3.6/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:541: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/ioz/.local/lib/python3.6/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:542: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/ioz/.local/lib/python3.6/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:543: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/ioz/.local/lib/python3.6/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:544: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/ioz/.local/lib/python3.6/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:545: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/home/ioz/.local/lib/python3.6/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:550: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
[ WARNING ] Model Optimizer removes pre-processing block of the model which resizes image keeping aspect ratio. The Inference Engine does not support dynamic image size so the Intermediate Representation file is generated with the input image size of a fixed size.
Specify the "--input_shape" command line parameter to override the default shape which is equal to (600, 600).
The Preprocessor block has been removed. Only nodes performing mean value subtraction and scaling (if applicable) are kept.
I trained the model for custom dataset using faster_rcnn_inception_v2_coco_2018_01_28 pre-trained model and create inference_graph. Is that a problem?
Thanks in Advance.
JesusE_Intel
Hi Malathi,
The faster_rcnn_support.json is only for the pre-trained model from the Open Model Zoo. You will need to use one of the following configuration files as you retrained the network. Make sure to match the same API version as the TensorFlow version used to train the model.
#Directory /opt/intel/openvino/deployment_tools/model_optimizer/extensions/front/tf
Additional information can be found here: https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_Object_Detection_API_Models.html#how_to_convert_a_model
Jesus
Kaliyappan__Malathi
Hi Jesus E,
I'm using OpenVINO toolkit R3 (openvino_2019.3.376).
I tried the all .json files mentioned above, but the error was same as in image1 (Please find the attached image)
These are the steps I followed:
1) I customized the pipeline.config
2)Then trained the RCNN model using this command
python3 train.py --logtostderr --train_dir=object_detection/training/ --pipeline_config_path=object_detection/training/pipeline.config
3)After completed the training I create .pb file from .ckpt files using this command
python3 export_inference_graph.py \
--input_type image_tensor \
--pipeline_config_path object_detection/training/pipeline.config \
--trained_checkpoint_prefix object_detection/training/model.ckpt-84211 \
--output_directory object_detection/New_inference_graph
While creating .pb to IR, I got the error.
Can you please help me with this.
Thanks in advance.
JesusE_Intel
Hi Malathi,
All the steps so far look correct, could you share your model and necessary files for me to walk though your steps?
I will send you a private message.
Jesus
JesusE_Intel
Hi Malathi,
Thanks for sending the model over PM, I took a look and I was not able to convert the model to IR format. I am having the development team take a look, I will let you know what we find out.
Jesus
Kaliyappan__Malathi
Hi Jesus E,
Can you please let me know If there is any update about this issue.
Thanks in Advance
JesusE_Intel
Hi Malathi,
Jesus
Kaliyappan__Malathi
Hi Jesus E.,
I have referred the link you gave. I need a clarification about the training process,
These are the steps I have followed for training
1) For training
 python3 train.py --logtostderr --train_dir=object_detection/training/ --pipeline_config_path=object_detection/training/faster_rcnn_inception_v2_coco.config
2) For creating inference graph
--pipeline_config_path object_detection/training/faster_rcnn_inception_v2_coco.config \
--trained_checkpoint_prefix object_detection/training/model.ckpt-116105 \
--output_directory object_detection/helmet_inference_graph
Please check the config file attached below
In that document they use ssd_mobilenet_v1_pets.config file  for training
(venv)$ python3 train.py --logtostderr --train_dir=training/ -- pipeline_config_path = training/ssd_mobilenet_v1_pets.config
But while creating inference graph they used faster_rcnn_inception_v_coco.config
(venv)$ python3 export_inference_graph.py \
	    --pipeline_config_path training/faster_rcnn_inception_v_coco.config \
	    --trained_checkpoint_prefix  training/model.ckpt-56129 \
	    --output_directory  faster_rcnn_inception_inference_graph
Is that a correct process?
Do I have to change the config file as like ssd_mobilenet_v1_pets.config
Thanks in advance
Kaliyappan__Malathi
Hi Jesus E.,
I followed the link you gave . I got the result.
Thank you :)
JesusE_Intel
Awesome! Thanks for letting me know.
Jesus
