I'm working on facenet with openvino R3 release,
I converted two version model( 20180402-114759, 20170512-110547) to test, but the output matrices are not the same(or the image are not the same) on the same image with original facenet.
The followings are my test steps:
1. Converted facenet model to openvino
~/intel/computer_vision_sdk/deployment_tools/model_optimizer$ python3 ./mo_tf.py --input_model '/home/aim/facenet/20170512-110547/20170512-110547.pb' --freeze_placeholder_with_value "phase_train->False"
2. Test the model output with original facenet
...... img = cv2.imread( "face.jpg" ) face = detectBYMTCNN(img) resized= cv2.resize( face, (160,160), interpolation=cv2.INTER_CUBIC ) reshaped= resized.reshape ( -1, 3, 160,160 )
facenet_net = IENetwork.from_ir( model="2017_facenet.xml", weights="2017_facenet.bin" ) facenet_plugin = IEPlugin( device="CPU" ) facenet_plugin.add_cpu_exrtension...... facenet_2017_exec_net = facenet_plugin.load( network = facenet_net, num_requests=1 ) facenet_res_2017 = facenet_2017_exec_net.infer( {'batch_join/fifo_queue': reshaped} ) embedding_2017 = facenet_res_2017['normalize'] # original_2017 is the pre-saved data using original facenet model dist_2017 = np.sqrt( np.sum( np.square( np.subtract( embedding_2017, original_2017 ) ) ) ) print( dist_2017 )
The code maybe not complete. I think the output matrix should be the same(or similar) with the same image between two models(original model and openvino model).
But the dist_2017 is larger than 1( the two images are not the same), and the 2018 model has the same result.
So I test another situation and find a strange thing, almost all my test sets are been recognized to the same face using converted model.
Does anyone get the same issue?
David
Hi David,
Our validation accuracy standard is 10^(-5) signs comparing TF blob output and Inference Engine blob output. I just checked that facenet passes this test. Probably the issue is in you measurements way: make sure you've got original_2017 the same way). Try to compare TF and IE output blobs elementwise up to 10^(-5) as we're doing.
Best wishes,
Anna
Hi Anna,
I will check that!
David
Hi Anna and David,
I do the same thing as David to inference the facenet model, but different of the 2017 and 2018 model are all larger than 1 for the same image on cpu. and I do the validate_on_lfw as facenet to check the accuracy of IR model it's only 0.58. Apparently the embedding result is wrong.
so any advise on it? Thanks.
Hi Feng,
If you have a question can you create a new post?
Kind Regards,
Monique Jones
![](/skins/images/01F111D2651B8D490886918A505C4147/responsive_peak/images/icon_anonymous_message.png)
