Failed to initialize Inference Engine backend: Unsupported primitive of type: PriorBoxClustered
AI_Next
Hi
I am trying to test the Intel Model "person-vehicle-bike-detection-crossroad-0078" using OpenCV. The model is loaded successfully with cv::dnn::readNetFromModelOptimizer. However, I have an error message complaining about "PriorBoxClustered" when I try to forward the result using "predictObjects". it seems that this type is not supported but appears in the list of supported layers: https://docs.openvinotoolkit.org/latest/_docs_IE_DG_supported_plugins_Supported_Devices.html
The full error message is the following:
OpenCV: terminate handler is called! The last OpenCV error is:
OpenCV(4.1.0-openvino) Error: Assertion failed (Failed to initialize Inference Engine backend: Unsupported primitive of type: PriorBoxClustered name: x08_priorbox) in cv::dnn::InfEngineBackendNet::initPlugin, file C:\jenkins\workspace\OpenCV\OpenVINO\build\opencv\modules\dnn\src\op_inf_engine.cpp, line 747
How this issue could be solved?
AI_Next
It has been fixed just by renaming cpu_extension_avx2.dll on cpu_extension.dll
Shubha_R_Intel
Dear AI Next,
Thanks for reporting back regarding your fix. It helps the community to see how people solved their issues.
And thanks for using OpenVino !
Shubha
Kesavaram__Jaiganesh
I am also getting the same error when testing face recognition with OpenCV and Openface model.
cv2.error: OpenCV(4.1.0-openvino) /home/jenkins/workspace/OpenCV/OpenVINO/build/opencv/modules/dnn/src/op_inf_engine.cpp:747: error: (-215:Assertion failed) Failed to initialize Inference Engine backend: Can not init USB device: NC_ERROR in function 'initPlugin'
May i know how to fix this issue for Ubuntu env?
liang__heng
Shubha R. (Intel) wrote:
Dear AI Next,
Shubha
HI,can you tell us why the "cpu_extension_avx2.dll"  need to be renamed by "cpu_extension.dll"
Shubha_R_Intel
Dear liang, heng,
I still see it named as cpu_extension_avx2.dll in OpenVino 2019R2.
Shubha
