How can I get "human-pose-estimation-3d-0001.xml"?
Anonymous101
https://docs.openvinotoolkit.org/latest/_demos_python_demos_human_pose_estimation_3d_demo_README.html
It cannot be acquired the file by Model downloader.
Version : openvino_2020.1.033 on Windows10
Thanks a lot,
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\tools\model_downloader>python downloader.py  --name human-pose-estimation-3d-0001  --output_dir C:\Users\USERNAME\Documents\Intel\OpenVINO\
################|| Downloading models ||################
========== Downloading C:\Users\USERNAME\Documents\Intel\OpenVINO\public\human-pose-estimation-3d-0001\human-pose-estimation-3d-0001.tar.gz
... 100%, 17990 KB, 8402 KB/s, 2 seconds passed
################|| Post-processing ||################
========== Unpacking C:\Users\USERNAME\Documents\Intel\OpenVINO\public\human-pose-estimation-3d-0001\human-pose-estimation-3d-0001.tar.gz
C:\Users\USERNAME>cd  C:\Users\USERNAME\Documents\Intel\OpenVINO\public\human-pose-estimation-3d-0001
C:\Users\USERNAME\Documents\Intel\OpenVINO\public\human-pose-estimation-3d-0001>dir
 Volume in drive C is OSDisk
 Volume Serial Number is 828F-8868
 Directory of C:\Users\USERNAME\Documents\Intel\OpenVINO\public\human-pose-estimation-3d-0001
2020/02/06  15:32    <DIR>          .
2020/02/06  15:32    <DIR>          ..
2019/10/08  22:55        20,509,788 human-pose-estimation-3d-0001.pth
2019/10/11  19:49    <DIR>          model
               1 File(s)     20,509,788 bytes
               3 Dir(s)  30,012,047,360 bytes free
C:\Users\USERNAME\Documents\Intel\OpenVINO\public\human-pose-estimation-3d-0001>cd model
C:\Users\USERNAME\Documents\Intel\OpenVINO\public\human-pose-estimation-3d-0001\model>dir
 Directory of C:\Users\USERNAME\Documents\Intel\OpenVINO\public\human-pose-estimation-3d-0001\model
2019/10/11  19:49    <DIR>          .
2019/10/11  19:49    <DIR>          ..
2019/10/08  20:10             1,237 conv.py
2019/10/11  19:45             8,016 with_mobilenet.py
2019/10/08  21:32                56 __init__.py
               3 File(s)          9,309 bytes
               2 Dir(s)  30,012,047,360 bytes free
JesusE_Intel
As Vladimir mentioned, the model downloader will download the PyTorch model. Use the following model optimizer command to convert to ONNX and then ONNX to IR format.
python <Installation_Dir>\openvino\deployment_tools\tools\model_downloader\pytorch_to_onnx.py --model-name=PoseEstimationWithMobileNet --weights=human-pose-estimation-3d-0001.pth --input-shape=1,3,256,448 --output-file=human-pose-estimation-3d-0001.onnx --output-names=features,heatmaps,pafs --input-names=data --model-param=is_convertible_by_mo=True --import-module=model
python <Installation_Dir>\intel\openvino\deployment_tools\model_optimizer\mo_onnx.py --input=data --mean_values=data[128.0,128.0,128.0] --scale_values=data[255.0,255.0,255.0] --output=features,heatmaps,pafs --input_model=human-pose-estimation-3d-0001.onnx
The required parameters can be found in the model.yaml on the Open Model Zoo.
Jesus
Vladimir_Dudnik
you use downloader script, which only download models (for public models it download them in source framework format). To get an OpenVINO IR from it you need to run converter script as a next step. It will convert model to OpenVINO IR through Model Opetimizer.
  Vladimir
JesusE_Intel
Jesus
pmx
The instructions of Jesus E. allowed me to convert the model in IR format.
Now I get the following error when I try to run the 3D Human Pose Estimation Python Demo on my ubuntu 18.04.
> python3 human_pose_estimation_3d_demo.py -m ~/openvino_models/public/human-pose-estimation-3d-0001/human-pose-estimation-3d-0001.xml
  File "human_pose_estimation_3d_demo.py", line 25, in <module>
    from modules.parse_poses import parse_poses
  File "/opt/intel/openvino_2020.1.023/deployment_tools/open_model_zoo/demos/python_demos/human_pose_estimation_3d_demo/modules/parse_poses.py", line 18, in <module>
    from pose_extractor import extract_poses
ImportError: cannot import name 'extract_poses'
Note that when I built the Openvino demos , I have used the flag ENABLE_PYTHON=ON :
cmake -DCMAKE_BUILD_TYPE=Release -DENABLE_PYTHON=ON /opt/intel/openvino/deployment_tools/inference_engine/demos
so that the pose_extractor.so was succesfully generated. But now I don't know how to make the connection between the "from pose_extractor import extract_poses" in parse_poses.py, with pose_extractor.so. Modidying the LD_LIBRARY_PATH to make it point to the directory where the .so is does not solve the problem.
Any idea ? Thanks
Kobu_Intel
Hi Vladimir, Jesus,
IR model was created!
Though I need to work on one more step below on Windows10.
https://software.intel.com/en-us/forums/intel-distribution-of-openvino-toolkit/topic/844756
BR/Kobu
Kobu_Intel
JesusE_Intel
Hi pmx,
You will need to export the PYTHONPATH to add the demo build directory, take a look at the steps in this thread. This is my export command after building the demos with the -DENABLE_PYTHON=ON.
export PYTHONPATH="$PYTHONPATH:/home/jesus/omz_demos_build/intel64/Release/lib"
Jesus
JesusE_Intel
Hi Kobu,
These are the steps for Windows, give it a try and let me know if it works for you.
Build the demos with the -DENABLE_PYTHON
cd C:\Program Files (x86)\IntelSWTools\openvino\inference_engine\demos
build_demos_msvc.bat -DENABLE_PYTHON=YES
Run the demo
cd C:\Program Files (x86)\IntelSWTools\openvino\inference_engine\demos\python_demos\human_pose_estimation_3d_demo
SET PYTHONPATH=%PYTHONPATH%;C:\Users\<USER_NAME>\Documents\Intel\OpenVINO\omz_demos_build\intel64\Release
python human_pose_estimation_3d_demo.py -h
Jesus
Kobu_Intel
Hi Jesus,
Worked at Windows10!!
I'll try Ubuntu next referring below.
 Thanks a lot!!
BR/Kobu
JesusE_Intel
Kobuna, Ryosuke (Intel) wrote:
FYI, typo:
https://docs.openvinotoolkit.org/latest/_demos_python_demos_human_pose_e...
python human_pose_"estination"_3d_demo.py \
Good catch, I've submitted a bug to have the documentation updated. Thanks!
Jesus
Pasteris__Paolo
After the previous usefully steps I obtained:
C:\Users\paolo.pasteris\Documents\Intel\OpenVINO\omz_demos_build\intel64\Release>human_pose_estimation_demo.exe -i cam -m C:\Users\paolo.pasteris\Documents\Intel\OpenVINO\public\human-pose-estimation-3d-0001\human-pose-estimation-3d-0001.xml -d CPU
InferenceEngine: 00007FF897434020
Parsing input parameters
[ ERROR ] C:\Users\paolo.pasteris\Documents\Intel\OpenVINO\public\human-pose-estimation-3d-0001\human-pose-estimation-3d-0001.xml: expected to have 2 outputs
Any suggestion?
Paolo
Huiyan_C_Intel
It's weird! I got following error:
mo.utils.error.Error: Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.front.user_data_repack.UserDataRepack'>): No node with name features.
when I tried to convert human-pose-estimation-3d-0001.onnx using
while I can see output nodes are features, heatmaps and pafs by opening human-pose-estimation-3d-0001.onnx with Netron.
Any ideas? Thanks!
deven_patel
I could  fix this by downgrading pytorch from 1.5 to 1.4
