How to use the OpenCL compiler of OpenVINO?
Chen__Oliver
Hi!
I'm considering the possibility of running OpenCL on the SHAVE processor of Intel Neural Compute Stick 2 (NCS2) connected to an ARM board (Dragonboard 410C). The target is use OpenCL to accelerate OpenCV applications, or even to other general purpose ones.
In this page: Release Notes for Intel® Distribution of OpenVINO™ toolkit 2019
There is a description about an OpenCL compiler:
HDDL Plugin
Added OpenCL™ custom layer support for the Intel® Vision Accelerator Design with Intel® Movidius™ VPUs in the Preview Feature mode:
OpenCL™ compiler, targeting SHAVE processor only, is redistributed with OpenVINO™. OpenCL support is provided by ComputeAorta, and is distributed under a license agreement between Intel and Codeplay Software Ltd.
I'm wondering if there is any other information about how to use this OpenCL compiler?
Oliver
David_C_Intel
Hello Oliver
Thank you for replying.
Looking through the DLDT repository under tools, we can see that OpenCL is not available. In fact, the only way to use OpenVINO™ toolkit on ARM is with DLDT, and it does not include OpenCL.
David
David_C_Intel
Hi Oliver,
Thank you for reaching out. This guide might be useful for your needs.
If you need additional help, feel free to post here again.
David
Chen__Oliver
Hi David,
Thank you for your reply and providing the link to that document.
Thanks to that guide, I've found the directory of OpenCL tools in the installed OpenVINO:
  <INSTALL_DIR>/deployment_tools/tools/cl_compiler
In that directory there are few binary executable files, which I believe are compiled for Intel x86 CPU.
As I want to use OpenVINO on ARM (the Dragonboard 410c board), I'm wondering whether I can:
1. find the source code of those OpenCL tools to compile for ARM, just like I compiled the Deep Learning Deployment Toolkit (DLDT) for ARM? or
2. find the binary executable of those OpenCL tools compiled for ARM?
David_C_Intel
Hello Oliver
David
Chen__Oliver
Hi David,
OK, now I understand.
Thanks for your reply and explanation!
