How to use yolov3 and openCV with the support NCS2
j__m
Hi
We are developing the project which is based on Intel NCS2, OpenVINO and OpenCV.
I want to run yolov3 models and OpenCV with NCS2 support to object detection.
I've converted yolov3 models to IR models using the following command:
python3 convert_weights_pb.py --class_names coco.names --data_format NHWC --weights_file yolov3.weights
and
python3 convert_weights_pb.py --class_names coco.names --data_format NHWC --weights_file yolov3-tiny.weights --tiny
python3 /mo_tf.py  --input_model frozen_darknet_yolov3_model.pb --tensorflow_use_custom_operations_config /extensions/front/tf/yolo_v3_tiny.json --input_shape=[1,416,416,3] --data_type FP32 //for CPU
python3 /mo_tf.py  --input_model frozen_darknet_yolov3_model.pb --tensorflow_use_custom_operations_config /extensions/front/tf/yolo_v3_tiny.json --input_shape=[1,416,416,3] --data_type FP16 //for MYRIAD
and
python3 /mo_tf.py  --input_model frozen_darknet_yolov3_model.pb --tensorflow_use_custom_operations_config /extensions/front/tf/yolo_v3.json --input_shape=[1,416,416,3] --data_type FP32 //for CPU
python3 /mo_tf.py  --input_model frozen_darknet_yolov3_model.pb --tensorflow_use_custom_operations_config /extensions/front/tf/yolo_v3.json --input_shape=[1,416,416,3] --data_type FP16 //for MYRIAD
Here is my json file:
for yolov3-tiny:
    "id": "TFYOLOV3",
    "match_kind": "general",
    "custom_attributes": {
      "classes": 80,
      "anchors": [10, 14, 23, 27, 37, 58, 81, 82, 135, 169, 344, 319],
      "coords": 4,
      "num": 6,
      "mask": [0, 1, 2],
      "jitter": 0.3,
      "ignore_thresh": 0.7,
      "truth_thresh": 1,
      "random": 1,
      "entry_points": ["detector/yolo-v3-tiny/Reshape", "detector/yolo-v3-tiny/Reshape_4"]
for yolov3:
    "id": "TFYOLOV3",
      "classes": 80,
      "coords": 4,
      "num": 9,
      "mask": [0, 1, 2],
      "entry_points": ["detector/yolo-v3/Reshape", "detector/yolo-v3/Reshape_4", "detector/yolo-v3/Reshape_8"]
Process was a complete success
I trying use converted model in OpenCV. Here code:
net = readNet(cfg.modelConfiguration, cfg.modelWeights);
net.setPreferableBackend(cfg.backend);
net.setPreferableTarget(cfg.target);
//recognize
blob = blobFromImage(frame, cfg.scale, Size(cfg.inpWidth, cfg.inpHeight), Scalar(), false);
net.setInput(blob);
vector<Mat> outs;
names = getOutputsNames(net);
net.forward(outs, names);
for (size_t i = 0; i < outs.size(); ++i)
    Mat prob = outs; //4-dimension Mat
    //get the coardinates
The code was run. But I don't know  how to get the coordinates of the bounding.
I tried like this:
 Mat prob = outs;
    Mat detectionMat(prob.size[2], prob.size[3], CV_32F, prob.ptr<float>());
            float* data = (float*)detectionMat.data;
            for (int j = 0; j < detectionMat.rows; ++j, data += detectionMat.cols)
                Mat scores = detectionMat.row(j).colRange(5, detectionMat.cols);
                Point classIdPoint;
                double confidence;
                // Get the value and location of the maximum score
                minMaxLoc(scores, 0, &confidence, 0, &classIdPoint);
                if (confidence > cfg.confThreshold)
                    ObjResult result;
                    cout << "confidence " << confidence << endl;
                    cout << "classIdPoint.x " << classIdPoint.x << endl;
                    // cout << "classes[classId] " << classes[classIdPoint.x] << endl;
                    result.centerX = (int)(data[0] * frame.cols);
                    result.centerY = (int)(data[1] * frame.rows);
                    result.width = (int)(data[2] * frame.cols);
                    result.height = (int)(data[3] * frame.rows);
                    result.confidence = confidence;
                    result.classId = classIdPoint.x;
                    result.className = classes[classIdPoint.x];
                    ret.objResults.push_back(result);
or:
Mat prob = outs;
            for(int c=0; c<numlabels; c++)
                int labelnum = (size_t)(detectionMat.at<float>(c, 1))-1;
                labelnum = (labelnum < 0) ? 0 : (labelnum > numlabels) ? numlabels : labelnum;
                cout << "labelnum: " << labelnum << endl;
                float confidence = detectionMat.at<float>(c, 2);
                cout << "confidence: " << confidence << endl;
                if(confidence > 0.5)
                    int classId = static_cast<int>(detectionMat.at<float>(c, 1));
                    int left = static_cast<int>(detectionMat.at<float>(c, 3) * frame.cols);
                    int top = static_cast<int>(detectionMat.at<float>(c, 4) * frame.rows);
                    int right = static_cast<int>(detectionMat.at<float>(c, 5) * frame.cols);
                    int bottom = static_cast<int>(detectionMat.at<float>(c, 6) * frame.rows);
                    ObjResult result;
                        result.width = right - left;
                        result.height = top - bottom;
                        result.centerX = left + result.width/2;
                        result.centerY = bottom + result.height/2;
                        result.classId = classId;
                        result.className = classes[classId];
But it's not proper way.
How can i get the coordinates of the bounding? Have you any sample code?
j__m
Dear Shubha R.
Thanks for your reply.
I have looked at the sample (also c++ sample: object_detection_demo_yolov3_async/main.cpp) However both examples are based on inference_engine (IENetwork, IEPlugin).
I'm trying to use only OpenCV DNN API, functions such as: readNet, blobFromImage, setInput and forward.
Very similar to sample: end2end_video_analytics_opencv, but use yolov3 model  instead of caffe.
Is it possible to do not use inference_engine?
By the way, sample don't work with my IR model. I got error: Sample supports only YOLO V3 based triple output topologies
Shubha_R_Intel
Dear j, m,
This forum is concerned with Model Optimizer and Inference Engine issues. Of course you can use OpenCV DNN API, but the below forum would be more receptive to your questions:
https://answers.opencv.org/questions/
Shubha
