IE::ie_cpu_extension not found
Daraen
ビギナー
1,846件の閲覧回数
Hi everyone,
I'm student and I'm working with OpenVINO for my intership.
So I tried to use the sample code with the samples :
http://docs.openvinotoolkit.org/latest/_inference_engine_samples_classification_sample_README.html
When I compile the code, an error occured and say that IE::ie_cpu_extension is not found.
Anyone can help me please ?
Thank you !
0 件の賞賛
1 解決策
Shubha_R_Intel
従業員
1,846件の閲覧回数
Dear Daraen:
If you downloaded OpenVino 2019 R1 and
executed C:\Program Files (x86)\IntelSWTools\openvino\setupvars.bat THEN
C:\Program Files (x86)\IntelSWTools\openvino\inference_engine\samples\build_samples_msvc2017.bat
it will build the samples and also cpu_extension.dll .  The binaries will be found under C:\Users\<MickeyMouse>\Documents\Intel\OpenVINO\inference_engine_samples_build_2017\intel64\Release
Similar instructions for the Linux version.
The OpenVino samples pass in cpu_extension.dll via the -l command-line argument.
Shubha
元の投稿で解決策を見る
3 返答(返信)
Shubha_R_Intel
従業員
1,847件の閲覧回数
Dear Daraen:
Shubha
Daraen
ビギナー
1,846件の閲覧回数
Hello Shubha,
Thank you for your reply.
I did what you said but I don't know what to do with the files built.
I changed the name IE::ie_cpu_extension.lib to cpu_extension.lib in the entry of the part "Linker" in Visual Studio, and I got lot of errors.
EDIT: the .bat file created only a Release directory (with files insides) and no Debug directory.
RE-EDIT : All work, thank you
Shubha_R_Intel
従業員
1,846件の閲覧回数
Dear  Daraen,
You are correct in that only Release binaries get built by default. However you will find a Samples.sln under inference_engine_samples_2017 and you can pull that *.sln file up in Visual Studio, configure for Debug and build that from within Visual Studio.
Please follow the OpenVino samples regarding how to reference cpu_extension.dll in the code. Normally you will never have to modify cpu_extension.dll unless you're creating a custom layer.
Shubha
返信
