6605 Discussions
ISSUE SOLVED :: Error with custom uploaded non-annotated input data (DL Workbench)
niclas1992
I uploaded and converted an onnx model to IR format using the Openvino DL Workbench. For input data I chose the gray scale images I used when training the network also, and uploaded 100 of them packed in a zip  structure. When trying inference, following Error occurs:
[ ERROR ] 'NoneType' object has no attribute 'shape'
Traceback (most recent call last):
File "/usr/local/lib/python3.8/dist-packages/openvino/tools/benchmark/main.py", line 375, in run
data_queue = get_input_data(paths_to_input, app_inputs_info)
File "/usr/local/lib/python3.8/dist-packages/openvino/tools/benchmark/utils/inputs_filling.py", line 113, in get_input_data
data[port] = get_image_tensors(image_mapping[info.name][:images_to_be_used_map[info.name]], info, batch_sizes_map[info.name])
File "/usr/local/lib/python3.8/dist-packages/openvino/tools/benchmark/utils/inputs_filling.py", line 155, in get_image_tensors
if image.shape[:-1] != new_im_size:
AttributeError: 'NoneType' object has no attribute 'shape'
 I attached the corresponding server_log.
For further information if useful: Before I used the default images which got rejected for another error because of having three channels (not grayscale) while my network is using 1 channel as input.
Best Regards
Niclas
niclas1992
sorry for the inconvenience, the error consisted in using the wrong image format (.webp)
Regards Niclas
Hairul_Intel
Hi Niclas,
For sharing purposes, the Not Annotated Datasets uses .jpg image format. The archive for not annotated dataset is organized as follows:
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Hairul
