6594 Discussions
ImportError:undefined symbol: _ZN15InferenceEngine7details23CNNNetSortTopologicallyERKNS_11ICNNNetworkE
Davis__Thomas
Hi!
    Recently, I have installed the l_openvino_toolkit_p_2019.1.144.tgz,When I run the toolkit python example, I will encounter a error as follows:
Traceback (most recent call last):
  File "object_detection_demo_ssd_async.py", line 25, in <module>
    from openvino.inference_engine import IENetwork, IEPlugin
  File "/opt/intel/openvino_2019.1.144/python/python3.5/openvino/inference_engine/__init__.py", line 1, in <module>
    from .ie_api import *
ImportError: /opt/intel/openvino_2019.1.144/python/python3.5/openvino/inference_engine/ie_api.so: undefined symbol: _ZN15InferenceEngine7details23CNNNetSortTopologicallyERKNS_11ICNNNetworkE
I hope someone can give advice
Thank you!
Shubha_R_Intel
Dear Davis, Thomas,
Actually wow - l_openvino_toolkit_p_2019.1.144.tgz is super ancient. We are on 2019R3 by now. Can you kindly uninstall that and re-install everything from scratch, this time using 2019R3. Also /python3.5/ is pretty old as well. 3.5 is supported but 3.6 or 3.7 would be better because Python has improved a lot too !
Please install the new versions (after properly uninstalling the old OpenVino and Python versions) and try again.
Hope it helps,
Shubha
