6573 Discussions
Is there API-doc or C++-samples to process Stereo-cameras on Myriad X (VPU)?
ABoch5
Is there API documentation and C++-examples to write my own C++-code to get depth-map on Myriad X (VPU) chip by using my own Stereo-camera (2 web-cameras)?
Sahira_Intel
Hi ABoch5,
I don't think there are any C++ examples to process stereo cameras in the OpenVINO Toolkit. But a NCS community member, Pinto, has a lot examples using the NCS2 + Intel Realsense D435 + MobileNetSSD that might be helpful to you. Check out his github repo here
But can you please describe your use case a little better? I can do a little more research to see if there are more examples.
Sincerely,
Sahira
ABoch5
Hi Sahira, Thanks!
I want to process my custom Stereo Cameras by using Myriad X (VPU) chip in C++. How can I do this?
Does it mean, that I can use only Intel Realsense stereo-cameras with Myriad X chips?
Sahira_Intel
Hi ABoch5,
Okay, you should be able to do that. The Myriad X Chip has a Stereo Depth Accelerator that is able to simultaneously process 6 camera inputs (or 3 stereo pairs).
You can use any stereo camera - that functionality is not only limited to the RealSense cameras.
There aren't any samples included in the OpenVINO toolkit though. But Pinto's example can be a good place to start since he uses the RealSense IR sensor to detect distance to an object.
Please let me know if you have any further questions.
Sahira
