6577 Discussions
MYRIAD, VPU: JOB SCRIPT ERROR: Remote job failed, code: 1
iJema
Hi There,
I'm trying to run the person-vehicle-bike-detection-crossroad-0078 FP16 model on NC2 and VPU, but I ran into remote job failed error. I tried again but the same error shows up every time. The same happened with Intel UHD graphics and UHD-p630 GPU. Please have a look at the issue. I'm using DL Workbench.
Machine: idc004nc2
Device: Intel Movidius Myriad X VPU
Machine: idc062
Device: Intel(R) UHD Graphics [0x9a78] (iGPU)
Thanks and regards
Jemish M
Labels (2)
Hari_B_Intel
Hi iJema
I have tested DL Workbench with MYRIAD and it works fine now.
Feel free to test and if you still face a similar issue, please reach out to us and we will further investigate.
Thank you
Wan_Intel
Hi iJema,
Are you using the latest version of the OpenVINO™ Deep Learning Workbench which is 2022.1? On another note, If you have GPU and MYRIAD devices on the target machine, configure sudo privileges without a password to enable the DL Workbench to set up devices automatically.
Wan
iJema
Hi Wan,
Thanks for replying. Yes, I'm using the latest version 2022.1. Also, I launch the DL workbench from Jupyter lab. Not sure about target machine. Will checkout.
Thanks and regards
iJema
Hari_B_Intel
Hi iJema
apology for the late, this is a known issue for DevCloud, our team is trying to fix the issue for MYRIAD and will get back to you ASAP.
Hari_B_Intel
Hi iJema
Thank you
iJema
Hi @Hari_B_Intel
Thanks for the confirmation! I'll try it out and let you know if I face any other issues.
Thanks and have a good day
