MYRIAD device, error: Dims and format are inconsistent
hake__malte
Hi, for batch size > 1i get the error "Failed to call QueryNetwork for MYRIAD device, error: Dims and format are inconsistent."
The optimized model is the Tensorflow slim model resnet_v2_50.
[ INFO ] InferenceEngine:
API version ............ 2.0
Build .................. custom_releases/2019/R2_f5827d4773ebbe727c9acac5f007f7d94dd4be4e
Description ....... API
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 2
[ INFO ]     /home/malte/val2017_test/000000007574.jpg
[ INFO ]     /home/malte/val2017_test/00000000757.jpg
[ INFO ] Creating Inference Engine
GPU
clDNNPlugin version ......... 2.0
Build ........... 27579
HETERO
heteroPlugin version ......... 2.0
Build ........... heteroPlugin
MYRIAD
myriadPlugin version ......... 2.0
[ INFO ] Loading network files
[ INFO ] Preparing input blobs
[ WARNING ] Image is resized from (640, 480) to (224, 224)
[ INFO ] Batch size is 2
[ INFO ] Loading model to the device
[ ERROR ] Failed to call QueryNetwork for MYRIAD device, error: Dims and format are inconsistent.
Can you tell me what is wrong here?
Malte
Shubha_R_Intel
Dear hake, malte,
Please give me more information about your model. Also please give me the model optimizer command you used as well. I see that you are using OpenVino 2019 R2 (from API version ............ 2.0) so that is good.
What happens when you run your code on CPU ?
Shubha
