- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Dear OpenVino Guru,
Hi, this is Tony. And I'm back.
Here is my model, retrained and based on Yolo V5.
https://drive.google.com/file/d/14XwO6OHHFDUSKFxhHphNZqlbDIIlEpxS/view?usp=sharing
Question 1:
My current model has no input limit for the image height and width.
Is it possible that I also does not preset the image size in the transformed IR model?
Question 2:
Previously, one of your Guru, Aznie, helped me to run the optimizer, but he stopped before the step where error occurs.
And I do need the full model result.(no mid-way.)
His command:
$python mo.py --input_model model.onnx --output Conv_410,Conv_322,Conv_498 --input_shape [1,3,512,512]
(I've even twist 512,512 to 480,640, to let the inference step pass)
However, using Netron to visualized the model, I've found that the last 1/5 of the model is truncated .
Running without "--output", I've got errors like:
[ ERROR ] The ExpandDims node Unsqueeze_333 has more than 1 input
[ ERROR ] The ExpandDims node Unsqueeze_583 has more than 1 input
Please see the attachment for the full output.txt and the results with --log_level=DEBUG
Please help me out.
With Regards.
Tony
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Tony Wong,
My apologies for the previously shared input.
On our replication, we faced the same error as yours when we exclude the --output argument from the MO command. Our findings indicated that our current version is not able to perform unsqueeze function with 2 inputs (data, axes) for the ONNX model.
Our development team is working to rectify this as PR-8399 has been initiated and is pending merging to the master branch.
https://github.com/openvinotoolkit/openvino/pull/8399)
Once merged, you may update your local repository by pulling the master branch using this command:
git pull https://github.com/openvinotoolkit/openvino/tree/master
If you were previously installed OpenVINO using our distribution package, regret to inform that you might need to build the open-source OpenVINO to enjoy this fix.
Temporarily, the current workaround that we would propose is to specify the --input_shape and --output arguments to allow the model to be converted successfully.
Sincerely,
Zulkifli
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Tony Wong,
I’m able to convert your model using the recommended MO command from the previous thread.
Specifying the input_shape argument is optional. But some models require using this additional argument to specify the conversion parameter.
Sincerely,
Zulkifli
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks, Zulkili.
Apparently, you did not read my post at all. You are wasting our time.
In the above post, I have explained why former command does not work at all.
In short, I want the final result ,not the middle way result. Not the result before error occurs.
Please take a look.
Tony
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Tony Wong,
Sincerely,
Zulkifli
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Many thanks, Zulkifli.
This is exactly what I'm looking for.
Thanks, I will watch this PR on the first moment.
Tony
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Oh, one tiny small question.
That PR is there 8 days ago. And not so much code change.
Usually how many days for a PR in Intel , will be reviewed and merged.
So that I can let my director know the estimation date.
Tony
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello Tony Wong,
We do not have any specific or estimated time the PR will be merged and released. It all depends on the internal processes of validation, testing, and approval.
Sincerely,
Zulkifli
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello TonyWong,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Sincerely,
Zulkifli
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello TonyWong,
The PR 8399 has been merged, feel free to try with the latest branch. If you faced any issues, please open a new case.
Sincerely,
Zulkifli
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I have tried, and it works . Thank you, Mr. Zulkifli
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
