Model optimization ERROR and tf==1.14
Xingping_L_Intel
[ ERROR ]  Shape is not defined for output 0 of "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice_1".
[ ERROR ]  Cannot infer shapes or values for node "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice_1".
[ ERROR ]  Not all output shapes were inferred or fully defined for node "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice_1".
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #40.
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function Slice.infer at 0x7f4df8ef56a8>.
[ ERROR ]  Or because the node inputs have incorrect values/shapes.
[ ERROR ]  Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ ERROR ]  Run Model Optimizer with --log_level=DEBUG for more information.
[ ERROR ]  Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Stopped shape/value propagation at "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice_1" node.
 For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #38.
HemanthKum_G_Intel
Hi Xingping,
Could you share more details like which model, from where to download for testing, Model Optimizer command-line arguments used?
Try using --reverse_input_channels if it is required.
Ref. http://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_Object_Detection_API_Models.html
