- NCS 2 wouldn't be detected correctly by NCSDK example hello_ncs_py
➜ hello_ncs_py lsusb
Bus 001 Device 007: ID 03e7:2485 Intel Movidius MyriadX
➜ hello_ncs_py python hello_ncs.py
D: [ 0] ncDeviceCreate:307 ncDeviceCreate index 0
D: [ 0] ncDeviceCreate:307 ncDeviceCreate index 1
D: [ 0] ncDeviceOpen:523 File path /usr/local/lib/mvnc/MvNCAPI-ma2480.mvcmd
W: [ 0] ncDeviceOpen:527 ncDeviceOpen() XLinkBootRemote returned error 3
Error - Could not open NCS device.
- C++ object_detection_sample_ssd failed to run.
➜ samples ./cpp/build/armv7l/Release/object_detection_sample_ssd -m face-detection-adas-0001.xml -d MYRIAD -i me.jpg
[ INFO ] InferenceEngine:
API version ............ 2.1
Build .................. custom_releases/2020/1_d349c3ba4a2508be72f413fa4dee92cc0e4bc0e1
Description ....... API
Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ] Loading Inference Engine
[ INFO ] Device info:
MYRIAD
myriadPlugin version ......... 2.1
Build ........... 37988
[ INFO ] Loading network files:
face-detection-adas-0001.bin
[ INFO ] Preparing input blobs
[ INFO ] Batch size is 1
[ INFO ] Preparing output blobs
[ INFO ] Loading model to the device
[ INFO ] Create infer request
[ WARNING ] Image is resized from (924, 1280) to (672, 384)
[1] 9179 segmentation fault ./cpp/build/armv7l/Release/object_detection_sample_ssd -m -d MYRIAD -i me.jp
Program hangs here and quit automatically on my Raspberry Pi4, but working fine on my laptop.
Can anybody take a look at it?
Thank you very much...
Pei
Hi Pei,
Thanks for reaching out.
- It seems you are using the Intel® Movidius™ Neural Compute SDK with the Intel® Neural Compute Stick 2, you can check here the supported SDKs for both Intel® NCS. If you want to use the Intel® NCS2, you will need to transition from the NCSDK to the OpenVINO™ toolkit, you can check how to in this guide.
- We tested the sample and it ran successfully with the following command:
./object_detection_sample_ssd -i TEST.jpeg -m face-detection-adas-0001.xml -d MYRIAD
Remember to use the xml file from the R3 2019 version of OpenVINO™ toolkit with its corresponding .bin file.
Do you have a fresh installation of Raspbian OS? You can try to reinstall its OS, test it again and tell us if it works.
David C.
A Contingent Worker at Intel
![](/skins/images/E799062D82CA2A220ED12C6FD1960495/responsive_peak/images/icon_anonymous_message.png)
Topic Options
