6584 Discussions
NCS2 / OpenVino 2019.1 on RPi: Segmentation fault after execution of last line of code
WG1
Hi everybody,
I have setup a RPi 3B+ and NCS2 based on the OpenVino Release l_openvino_toolkit_raspbi_p_2019.1.094. I also created a custom model for MNIST and try to infer it by the code below.
Randomely the program either runs fine without any issues or crashes after printing the final output message. I get "*** Error in `./simpleclassification': corrupted double-linked list: 0x016eb5f0 ***" as well as "Segmentation fault".
On a virual box VM (Ubuntu 16.04) the code runs fine without any issues.
Does anybody have an idea what the root cause is and how this could be solved?
EDIT:
found the solution: https://software.intel.com/es-es/node/807238
WG1
Okay, found the solution myself.
As stated here https://software.intel.com/es-es/node/807238
 the compiler switch -march=armv7-a solves the problem
