NCS2 on hotplug.d platform (openwrt)
skrywenko
hi there  i am wonder if any might have knowlege on why i can not get NCS2 to work on a hotplug platform( openwrt router - intel based ) I can get openvino to work with cpu and gna . just not MYRIAD.
i wrote a hotplug script to emulate udev but  does not seam to work - i know you have 3 entries in your myriad rules  but one entry never shows up so i can not determine the version number so I think it for a different  device .
#!/bin/sh
echo "${PRODUCT}" >> /tmp/usb_add
#fi
ncs2_PRODID="3e7/2485/1"
if [ "${PRODUCT}" = "${ncs2_PRODID}" ]; then
if [ "${ACTION}" = "add" ]; then
# echo "usb added highspeed" >> /tmp/usb_add
if [ -z ${DEVNAME} ]; then
echo "transistion" #>> /tmp/usb_add
else
chmod 666 /dev/${DEVNAME}
echo "/dev/${DEVNAME}" >> /tmp/usb_add
# echo "setting prmission" >> /tmp/usb_add
fi
fi
fi
ncs2_PRODID="3e7/f63b/100"
# echo "usb added superspeed" >> /tmp/usb_add
else
# echo "setting permission" >> /tmp/usb_add
fi
fi
fi
and it switching  permission on device when it switches from high speed  to super speed device. ( some part of the code is just debugging info)
and this is the output  i get from benchmark_app when running it
I: [ncAPI] [ 944074] [benchmark_app] ncDeviceOpen:926 ncDeviceOpen() XLinkBootRemote is running for 1.1.2-ma2480...
I: [ncAPI] [ 944305] [benchmark_app] ncDeviceOpen:944 ncDeviceOpen() XLinkBootRemote returned success X_LINK_SUCCESS for 1.1.2-ma2480
E: [ncAPI] [ 959305] [benchmark_app] ncDeviceOpen:1013 Failed to find booted device after boot
W: [ncAPI] [ 959305] [benchmark_app] ncDeviceOpen:1015 Device (1.1.2-ma2480) doesn't disappear after firmware loading
I: [ncAPI] [ 959305] [benchmark_app] destroyDeviceHandle:1651 Destroying device handler
I: [ncAPI] [ 959305] [benchmark_app] ncDeviceClose:1685 Handle already destroyed
[ ERROR ] Failed to allocate graph: MYRIAD device is not opened.
thank you for your time
skrywenko
add info:
you can see it booting the device;  lsusb output:
Bus 001 Device 005: ID 214b:7000  USB2.0 HUB
Bus 002 Device 009: ID 03e7:f63b Intel Corporation VSC Loopback Device
Bus 002 Device 007: ID 05e3:0626 GenesysLogic USB3.1 Hub
and that the permissions are set
crw-rw----    1 root     root      189, 136 Jun 13 18:36 /dev/bus/usb/002/009
when I trace the device interactions on a  ubuntu loaded  computer . it appears identical.  from what i can tell
the dmesg output
[31815.429909] usb 1-1.2: new high-speed USB device number 23 using xhci_hcd
[31941.185788] usb 1-1.2: USB disconnect, device number 23
[31941.443153] usb 2-1.2: new SuperSpeed Gen 1 USB device number 9 using xhci_hcd
[31953.999446] usb 2-1.2: USB disconnect, device number 9
[31954.553395] usb 1-1.2: new high-speed USB device number 24 using xhci_hcd
plus i forgot to mention it running in a chroot enviroment  on openwrt. and other methods work such as cpu and gna . I have not tried  GPU as  it  has a gen 8  intel video processor (N3160).  I have an gen 9 N100 next week.  the project is an all in one low power (~5w)  in AI house controller.   router/firewall/vpn/IDS , zigbeehub(zigbee2mqtt)  automation(domoticz)  database NAS . voice controlled AI. zoneminder and currently I wanted to add in  video  facial recognition at entry points hence the myriad device
Peh_Intel
Hi skrywenko,
According to Configurations for Intel® Neural Compute Stick 2, there are 3 rules in 97-myriad-sbboot.rules as follow.
SUBSYSTEM=="usb", ATTRS{idProduct}=="2150", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0660", ENV{ID_MM_DEVICE_IGNORE}="1"
SUBSYSTEM=="usb", ATTRS{idProduct}=="2485", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0660", ENV{ID_MM_DEVICE_IGNORE}="1"
SUBSYSTEM=="usb", ATTRS{idProduct}=="f63b", ATTRS{idVendor}=="03e7", GROUP="users", MODE="0660", ENV{ID_MM_DEVICE_IGNORE}="1"
Please try to include product ID,2150 as well.
Peh
skrywenko
thank you for the reply Peh
would you know the bcdDevice  # for  ID 2150 it never pops up in dmesg  whether running under openwrt  or in ubuntu20.04 or 22.04
as I can not get hotplug to work with out knowing it
[81686.170988] usb 6-1: New USB device found, idVendor=03e7, idProduct=2485, bcdDevice= 0.01
[81686.171002] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[81686.171011] usb 6-1: Product: Movidius MyriadX
[81686.171018] usb 6-1: Manufacturer: Movidius Ltd.
[81686.171023] usb 6-1: SerialNumber: 03e72485
[81762.135355] usb 6-1: USB disconnect, device number 30
[81762.468095] usb 7-1: new SuperSpeed USB device number 28 using xhci_hcd
[81762.493283] usb 7-1: New USB device found, idVendor=03e7, idProduct=f63b, bcdDevice= 1.00
[81762.493303] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[81762.493328] usb 7-1: Product: VSC Loopback Device
[81762.493335] usb 7-1: Manufacturer: Intel Corporation
[81762.493341] usb 7-1: SerialNumber: 3044F81051C6C2B900
[82082.321718] usb 1-3: USB disconnect, device number 19
also this line in my hotplug.d  script "echo "${PRODUCT}" >> /tmp/usb_add"  prints  every   dev/bus/usb  events .  to a log file called usb_add.
example out put to usb_add
5e3/610/6205
5e3/610/6205
5e3/610/6205
5e3/610/6205
5e3/610/6205
3e7/2485/1
usb added highspeed-0
usb added highspeed-1
/dev/bus/usb/001/022
3e7/2485/1
3e7/2485/1
3e7/2485/1
3e7/2485/1
3e7/2485/1
3e7/f63b/100
usb added superspeed-0
usb added superspeed-1
/dev/bus/usb/002/008
3e7/f63b/100
3e7/f63b/100
3e7/f63b/100
3e7/f63b/100
3e7/f63b/100
3e7/2485/1
/dev/bus/usb/001/023
3e7/2485/1
3e7/2485/1
5e3/610/6205 is a usb device that was plugged in before the  myriad device was plugged in
once the myriad is plugged in ->3e7/2485/1
3e7/2485/1      -> connected /detected
usb added highspeed-0       -> transition stage  when no dev/bus/usb has being allocated
usb added highspeed-1      ->  stage when /dev/bus/usb is allocated
/dev/bus/usb/001/022        ->  the  the setting of the permissions for MYRAID device (highspeed)
3e7/2485/1
usb added highspeed-0       -transition to prepare for super speed  device
3e7/2485/1    ...
when MYRIAD device  switches over  to VCS loop back  -> 3e7/f63b/100
3e7/f63b/100     -> connected/detected
usb added superspeed-0      -> transition stage  when no dev/bus/usb has being allocated
usb added superspeed-1       ->  stage when /dev/bus/usb is allocated
/dev/bus/usb/002/008         ->    the setting of the permissions for VCS loopback  device (superspeed)
3e7/f63b/100
usb added superspeed-0    ->  detransitioning stage back to highspeed
at no point does ID,2150  on the USB bus  display itself
Peh_Intel
Hi skrywenko,
Thanks for the clarification. Yes, product ID:2150 is not required.
To use MYRIAD plugin, please ensure that you download OpenVINO™ Runtime 2022.3 from the archive file and update the environment variables by running the setupvars.sh script before running Benchmark_app with NCS2.
Peh
Peh_Intel
Hi skrywenko,
This thread will no longer be monitored since we have provided answers. If you need any additional information from Intel, please submit a new question.
Peh
