ONNX Model GenAI C# Sample
RamaSubbuSK
Einsteiger
1.668Aufrufe
Hi all'
Is openVINO supported for ONNX GenAI Managed ? Is so how do I configure the Execution Provider in the C# code?
using Config config = new Config(modelPath);
config.ClearProviders();
config.AppendProvider("cpu");
In the solution add the reference nuget package NuGet Gallery | Intel.ML.OnnxRuntime.OpenVino 1.20.0
How to configure and load the VinoProvider?
3 Antworten
Wan_Intel
1.566Aufrufe
Dear RamaSubbuSK,
We are currently checking the method to configure Intel.ML.OnnxRuntime.OpenVino in C# code the relevant team. We will get back to you as soon as we have an update. We appreciate your understanding and will keep you updated.
Wan
Wan_Intel
1.549Aufrufe
Dear RamaSubbuSK,
Currently, we do not have any application or library that uses C# for OpenVINO™ GenAI. We do have OpenVINO™ library that supports Python and C++. On the other hand, OpenVINO™ Execution Provider is the documentation guide on how to code OpenVINO™ with C#, but we cannot guarantee that it works:
To configure Intel.ML.OnnxRuntime.OpenVino in C#, follow these steps:
  • Install Required Packages. In your C# project, install the required ONNX Runtime with OpenVINO™ Execution Provider via NuGet:
sh
dotnet add package Microsoft.ML.OnnxRuntime.OpenVINO
  • Load ONNX Model with OpenVINO™ Execution Provide. Create a C# console application and use the following code to configure OpenVINO™ as the execution provider:
csharp
using System;
using Microsoft.ML.OnnxRuntime;
class Program
   static void Main()
       string modelPath = "your_model.onnx";
       // Create an ONNX Runtime session with OpenVINO Execution Provider
       var sessionOptions = new SessionOptions();
       sessionOptions.AppendExecutionProvider_OpenVINO(); // Uses OpenVINO by default
       // Load the model
       using var session = new InferenceSession(modelPath, sessionOptions);
       // Print available execution providers
       Console.WriteLine("Available Execution Providers:");
       foreach (var provider in session.GetExecutionProviderNames())
           Console.WriteLine(provider);
  • Run Inference Using OpenVINO™. Modify the code to perform inference:
csharp
using System;
using System.Linq;
using Microsoft.ML.OnnxRuntime.Tensors;
class Program
   static void Main()
       sessionOptions.AppendExecutionProvider_OpenVINO(); // Enable OpenVINO EP
       // Prepare input (modify shape as per model)
       var inputName = session.InputMetadata.Keys.First();
       var inputShape = session.InputMetadata[inputName].Dimensions;
       float[] inputData = new float[inputShape.Aggregate(1, (a, b) => a * (b > 0 ? b : 1))];
       var inputTensor = new DenseTensor<float>(inputData, inputShape);
       var inputs = new NamedOnnxValue[] { NamedOnnxValue.CreateFromTensor(inputName, inputTensor) };
       // Run inference
       using var results = session.Run(inputs);
       var output = results.First().AsTensor<float>();
       Console.WriteLine("Inference completed. Output size: " + output.Length);
  • Optimize OpenVINO™ Execution. You can specify OpenVINO™-specific hardware accelerators:
csharp
sessionOptions.AppendExecutionProvider_OpenVINO("GPU"); // Use GPU
sessionOptions.AppendExecutionProvider_OpenVINO("VPU"); // Use Intel VPU
sessionOptions.AppendExecutionProvider_OpenVINO("CPU_FP32"); // Use CPU with FP32 precision
For more details on OpenVINO™ execution providers, refer to OpenVINO™ Execution Provider.
Wan
Wan_Intel
1.336Aufrufe
Hi RamaSubbuSK,
This case will no longer be monitored since we have provided suggestion. If you need further assistance, please submit a new question.
Wan
Antworten
