OpenVINO 2018 R2 build with VS2015 debug mode Failed
KCHEN80
I try to build a Debug mode application with VisualStudio 2015, but the code will throw an exception when entry findPlugin() the device(TargetDevice::eCPU)
And Release version the code workable.
see. the below for Exception status
KCHEN80
Update
find out root cause due to  OS first search 'inference_engine.dll' is 'Release'  (installed OpenVINO will added Release version path into PATH)
Maybe change shared library name difference is solution
like Microsoft to attached 'd' for Debug version
Severine_H_Intel
Dear Kunyi,
thank you for reporting this issue, I will submit your fix to the dev team.
Best,
Severine
lb3
This issue has yet to be fixed.  Same thing encountered in VS2017
Correction: The latest version of OPENVINO did indeed fix it.  Thanks.
See https://forums.intel.com/s/question/0D50P000049vvY9SAI/unable-to-run-inference-on-the-two-openvino-sample-models-security-barrier-and-classification-simple-in-debug-mode-windows-10?language=en_US
