OpenVINO on FPGA / Resource Busy
Kai-Feng_C_Intel
 I tried to use OpenVINO on FPGA. And it will report - "Error Opening AFC resource busy".
I used strace to check system call. I found the error is about /dev/intel-fpga-port.0 is busy. And I'd also found in the previous tried was available and worked but failed in last two tried. So the inference sample code exit.
Does anybody now how to fix it.?
Alexey_M_Intel1
Hello, Kai-Feng
Could you please try OpenVINO 2018 R 2.0.2 bugfix package l_openvino_toolkit_fpga_p_2018.2.319?
It is available in IRC and includes fix for this issue.
Kai-Feng_C_Intel
 I'm using OpenVINO 2018.2.30, DLA 1.01 and DCP 1.1. Could I know where to get 2.319?
Kai-Feng_C_Intel
Thanks and it's odd. I didn't see it this morning. thanks for notice.
Kai-Feng_C_Intel
 I found the issue. The issue is bbs and opae sdk version mismatch. I don't why it happend because it appeared in the same package.
Anyway, i'd already update everything (not openvino) to newest and it worked fine for me now.
I'll test newer openvino later.
Regards, maple
mahinlma
We updated latest openvino 2.319
In classification model, we are getting issue mentioned below... please let us know the reason
Emulator Context callback: Argument index is too large
ERROR: CL_INVALID_ARG_INDEX
Location: /teamcity/work/scoring_engine_build/releases/cvsdk-2018-r2/thirdparty/dla/api/src/dla_runtime.cpp:788
Failed set arg
