I am trying to run the demo example. I just did a fresh installation of Open Vino. I have Python 3.7 and Visual Studio 2017 installed.
demo_squeezenet_download_convert_run.bat
However I keep getting the error
c:\intel\computer_vision_sdk_2018.4.420\deployment_tools\inference_engine\src\extension\common\softmax.h(92): er
ror C3861: '_mm_blendv_ps': identifier not found
I could not find any references to this error. Could you please guide me as to what may be going wrong.
Dear Oniel,
we do not support Python 3.7 yet. I don't think this is the cause of the error, can you identify in the script which line throws this error?
Best,
Severine
Hi Severine,
I have attached the full output of the run.
The error occurs in this segment of the script
echo ###############^|^| Build Inference Engine samples using MS Visual Studio (MSBuild.exe) ^|^|###############
echo.
timeout 3
echo "%MSBUILD_BIN%" Samples.sln /p:Configuration=Release /t:classification_sample /clp:ErrorsOnly /m
if ERRORLEVEL 1 GOTO errorHandling
timeout 7
Oniel
Dear Oniel, the error is from a SEE4.1 instruction that seems to be unknown from your system, even though SEE4.1 is supported in your system as the long list in your debug file is showing. I dont know the cause and I would like to report your issue to our dev team.
Which CPU are you using?
Can you compile the samples directly from the inference_engine/samples folder by running create_msvc2017_solution.bat ? and report what happens when compiling those samples in VS 2017?
Best,
Severine
Dear Oniel, the script only creates a VS solution. You need to open the solution (.sln) which will be in your documents folder under Intel\OpenVINO\inference_engine_samples_2017. Then, you will need to compile the code.
Best,
Severine
replacing "#include <emmintrin.h>" by "#include <nmmintrin.h>" in "c:\intel\computer_vision_sdk_2018.4.420\deployment_tools\inference_engine\src\extension\common\defs.h" helped the samples compile and the "_mm_blendv_ps" error wasn't triggered anymore.
Thanks Severine - I was able to solve the problem. I compiled the code on an I7 and it worked fine.
Hi Severine!
I have the exact same problem. OpenVINO ver 2018.4.420, VS 2017, Python 3.7.1. Build err:
C:\Lib\OpenVINO\computer_vision_sdk\deployment_tools\inference_engine\src\extension\common\softmax.h(92): error C3861: '_mm_blendv_ps': identifier not found [c:\Users\Bleach\Documents\Intel\OpenVINO\inference_engine_samples_2017\ie_cpu_ex tension\ie_cpu_extension.vcxproj]
I use Intel i5 750 processor (Lynnfield):
Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Package (platform ID) Socket 1156 LGA (0x1)
CPUID 6.E.5
Extended CPUID 6.1E
which support SSE4.1, SSE4.2.
Hi Severine, I have the exact same error.
OpenVINO version - 2018.4.420
VS 2017 15.9.2
Python 3.7.1
I use Intel i5 750 CPU, which support SEE4.1 and SEE4.2.
Is there any solution to resolve this error?
Best regards, Yureg.
Hello Yureg,
I also had problems during sample compilations on my older desktop with i7 870 CPU which obviously supports SSE4.1 instructions. The comment made by Costi to change the included header file might help. It could be changed from emmintrin.h to either smmintrin.h (SSE4.1) or nmmintrin.h (SSE4.2). Although I may open a new ticket/topic why emmintrin.h was used.
I have further instructions/explanation written on my blog post.
Hope this could help!
I'm having a similar problem whilke trying to build both demos and samples,
my specific error is about "_mm512_floor_ps: identifier not found"
The machine I'm using features an Intel i9-7940X which obviously supports both SEE4.1 and SEE4.2, nonetheless I tryied to replace "#include <emmintrin.h>" with "#include <nmmintrin.h>" as suggested by Costi Dumitrescu, but I had no luck, so I tryied to replace the "#include <emmintrin.h>" with any one header suggested by Joel E in its post, but again with no luck.
I then tried to just comment the
static inline __m512 _mm_uni_floor_ps(__m512 vec) { return _mm_uni_castsi_ps(vec); }
which was giving me the error and I noticed that this specific function was just used by 1 example featuring yolo so I just ended up editing the method by just removing _mm_uni_castsi_ps, like this: static inline __m512 _mm_uni_floor_ps(__m512 vec) { return vec; }, but the yolo example won't work..
Hi Harry,
I was able to reproduce this issue. What version of Visual Studio are you using?
Roy
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
