- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Trying to convert YOLOv3 model definde in Keras. I have frozen the session as frozen_graph.pb in text format (so that I can edit the input shapes). When I try the IR generation using mo_tf.py script part of openvino tools. I am getting the following errors.
[ ERROR ] List of operations that cannot be converted to Inference Engine IR:
[ ERROR ] Min (3)
[ ERROR ] Min
[ ERROR ] Min_1
[ ERROR ] Min_2
[ ERROR ] Where (6)
[ ERROR ] boolean_mask/Where
[ ERROR ] boolean_mask_1/Where
[ ERROR ] boolean_mask_2/Where
[ ERROR ] boolean_mask_3/Where
[ ERROR ] boolean_mask_4/Where
[ ERROR ] boolean_mask_5/Where
[ ERROR ] Round (3)
[ ERROR ] Round
[ ERROR ] Round_1
[ ERROR ] Round_2
[ ERROR ] NonMaxSuppressionV2 (3)
[ ERROR ] non_max_suppression/NonMaxSuppressionV2
[ ERROR ] non_max_suppression_1/NonMaxSuppressionV2
[ ERROR ] non_max_suppression_2/NonMaxSuppressionV2
[ ERROR ] Part of the nodes was not converted to IR. Stopped.
Details of OpenVino version: 2019.3.0-375-g332562022
Any suggestions/references would be much appreciated.
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi GSrin4,
Thank you for contacting Intel Customer Support, my name is David, I am glad to assist you.
I see you are having trouble with the IR generation. Could you please provide the following information:
- What was the model optimizer command used to convert to IR format?
- Is it a pre-trained model or a custom model?
- Could you provide the orignal model?
David C.
A Contingent Worker at Intel
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi David,
Thank you for the reply.
Please find my comments for the query.
- model optimizer command: python mo_tf.py --input_model_is_text --input_model frozen_graph.pb. (Input shape has been updated in the .pb file)
- It's custom model.
- Original model in the sense? I used this github repo: https://github.com/qqwweee/keras-yolo3
- If you need the .h5 weight file, I can attach that. (The output of training is .h5 file in this case)
Hope it helps,
Gunasekaran
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi GSrin4,
Thank you for the information given.
It seems there is a flag missing: --tensorflow_use_custom_operations_config "yolo_v3.json".
You can check the documentation on how to convert YOLO models to IR here. As you are using a custom model, you will need to modify the "yolo_v3.json" file to match your model.
I hope this will help you. If you are still experiencing some errors, you can send me your ".pb" file, so we can manage to replicate your issue and get to a solution.
David C.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi GSrin4,
I am contacting you to give a follow up on this case. Could you please tell me if the issue is solved?
I will help you further to any other questions you may have.
David C.
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
