- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
How to extract the boxes, class id, score from the results there using the person-vehicle-bike-detection-crossroad-yolov3-1020 Intel pre-trained model?
Consulting the object_detection_demo.py it's not clear how to do that compared to reading the model from Yolo weights and cfg, using the " classes, scores, boxes = model.detect(frame, CONFIDENCE_THRESHOLD, NMS_THRESHOLD)" call.
net = cv.dnn.readNet(person-vehicle-bike-detection-crossroad-yolov3-1020.xml, person-vehicle-bike-detection-crossroad-yolov3-1020.bin)
net.setPreferableBackend(cv.dnn.DNN_BACKEND_INFERENCE_ENGINE)
net.setPreferableTarget(cv.dnn.DNN_TARGET_CPU)
blob = cv.dnn.blobFromImage(frame, size=(416, 416))
net.setInput(blob)
out = net.forward()
for detection in out:
confidence = float(detection[2])
xmin = int(detection[3] * frame.shape[1])
ymin = int(detection[4] * frame.shape[0])
xmax = int(detection[5] * frame.shape[1])
ymax = int(detection[6] * frame.shape[0])
if confidence > 0.5:
cv.rectangle(frame, (xmin, ymin), (xmax, ymax), color=(0, 255, 0))
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Igor_F_Intel,
For your information, by running Object Detection Python* Demo with person-vehicle-bike-detection-crossroad-yolov3-1020, you can print the raw output inference results by using command -r or --raw_output_message.
You can execute the command as follow:
python object_detection_demo.py -i <path_to_input> -m <path_to_model>\person-vehicle-bike-detection-crossroad-yolov3-1020.xml -at yolo --raw_output_message
Wan
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Tks Wan for the support.
But what I need is not to use the python demo script as you described. I would like to get the inference's result and extract the bounding boxes, score, and class id, to use it on my own application.
The demo script you pointed out makes use of several other scripts that is very verbose/complex to embedded on my application.
best,
Igor
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Igor_F_Intel,
By executing --raw_output_message or -r with Object Detection Python* Demo, you will extract the Bounding Boxes, Detection Score, and Class ID from the inference’s result as shown in the attached picture:
Looking into the object_detection_demo.py, Line 213 to Line 224, you can find the function of extracting the Bounding Boxes, Detection Score, and Class ID from the inference’s result.
Hope this helps.
Wan
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Did you try OpenCV's DNN object_detection sample? -> https://github.com/opencv/opencv/blob/master/samples/dnn/object_detection.py
It reads parameters from the `models` file -> https://github.com/opencv/opencv/blob/master/samples/dnn/models.yml
There are no Intel/OpenVINO models in this file, but I assume person-vehicle-bike-detection-crossroad-yolov3-1020 is very similar to YOLOv3.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Maksim_S_Intel,
Thanks for providing your suggestions.
Hello Igor_F_Intel,
Have you solved the issue with the suggestions given by Maksim_S_Intel?
Wan
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Igor_F_Intel,
This thread will no longer be monitored since we have provided suggestions.
If you need any additional information from Intel, please submit a new question.
Wan
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
cv.dnn.readNet
Keep getting the error when trying to read openvino ir :
import cv2 as cv
net = cv.dnn.readNet(XML, BIN)
cv2.error: OpenCV(4.5.2-openvino) /home/pi/opencv/modules/dnn/src/dnn.cpp:3901: error: (-2:Unspecified error) Build OpenCV with Inference Engine to enable loading models from Model Optimizer. in function 'readFromModelOptimizer'
I did install openvino and run the initialization script on my raspberry pi4b ( with MYRIAD ) as per instructions in:
https://www.intel.com/content/www/us/en/support/articles/000057005/boards-and-kits.html
The initialization command is:
source /home/pi/openvino_dist/bin/setupvars.sh
How can I use cv.dnn.readNet without the error ?
