- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hello, I get this internal error when running the model optimizer on a Tensorflow model. The whole output is attached as a file, I can also provide the model if needed. I have seen in the forum that the optimizer has problems with strided slice layers, but have not found a solution. How can I get successfully create an IR of the model? Error output:
[ ERROR ] ------------------------------------------------- [ ERROR ] ----------------- INTERNAL ERROR ---------------- [ ERROR ] Unexpected exception happened. [ ERROR ] Please contact Model Optimizer developers and forward the following information: [ ERROR ] 0 [ ERROR ] Traceback (most recent call last): File "/opt/intel/computer_vision_sdk_2018.5.445/deployment_tools/model_optimizer/mo/main.py", line 325, in main return driver(argv) File "/opt/intel/computer_vision_sdk_2018.5.445/deployment_tools/model_optimizer/mo/main.py", line 267, in driver mean_scale_values=mean_scale) File "/opt/intel/computer_vision_sdk_2018.5.445/deployment_tools/model_optimizer/mo/pipeline/tf.py", line 297, in tf2nx replacer.find_and_replace_pattern(graph) File "/opt/intel/computer_vision_sdk_2018.5.445/deployment_tools/model_optimizer/mo/utils/replacement_pattern.py", line 28, in find_and_replace_pattern apply_pattern(graph, **self.pattern(), action=self.replace_pattern) # pylint: disable=no-member File "/opt/intel/computer_vision_sdk_2018.5.445/deployment_tools/model_optimizer/mo/middle/pattern_match.py", line 95, in apply_pattern action(graph, match) File "/opt/intel/computer_vision_sdk_2018.5.445/deployment_tools/model_optimizer/extensions/middle/TensorIteratorMerge.py", line 103, in replace_pattern cond_data = match['condition'].out_node(0) File "/opt/intel/computer_vision_sdk_2018.5.445/deployment_tools/model_optimizer/mo/graph/graph.py", line 332, in out_node return self.out_nodes(control_flow=control_flow)[key] KeyError: 0 [ ERROR ] ---------------- END OF BUG REPORT -------------- [ ERROR ] -------------------------------------------------
Model Optimizer arguments: Common parameters: - Path to the Input Model: /media/amitrevda/storage/openvino_toolkit/input_models/juno_body_appearance/mars-small128.pb - Path for generated IR: /media/amitrevda/storage/openvino_toolkit/output_models/ - IR output name: mars-small128 - Log level: DEBUG - Batch: Not specified, inherited from the model - Input layers: Not specified, inherited from the model - Output layers: Not specified, inherited from the model - Input shapes: [1,128,64,3] - Mean values: Not specified - Scale values: Not specified - Scale factor: Not specified - Precision of IR: FP32 - Enable fusing: True - Enable grouped convolutions fusing: True - Move mean values to preprocess section: False - Reverse input channels: False TensorFlow specific parameters: - Input model in text protobuf format: False - Offload unsupported operations: False - Path to model dump for TensorBoard: None - List of shared libraries with TensorFlow custom layers implementation: None - Update the configuration file with input/output node names: None - Use configuration file used to generate the model with Object Detection API: None - Operations to offload: None - Patterns to offload: None - Use the config file: None Model Optimizer version: 1.5.12.49d067a0
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Dear Martin,
which topology are you using? Can you send your model? (use the PM function). I will investigate this issue and escalate to the development team if necessary.
Best,
Severine
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Dear Severine,
Thanks for your answer. The model we've tried to convert can be found here: https://github.com/nwojke/deep_sort
(look for "Then, download pre-generated detections and the CNN checkpoint file from here.")
It is a Wide Residual Network, the CNN architecture is described in the following paper: https://arxiv.org/abs/1703.07402
Best,
Martin
PS: This problem has become irrelevant for us. I am providing this answer in case you are interested.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Habert, Severine (Intel) wrote:Dear Martin,
Best,
Severine
Any updates on the issue?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Dear Martin,
l have the same problem as yours.
So have you solved your problem?
Kathryn
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Best,
Severine
Dear Severine,
l meet with the same problem.
can you help me to solve it?
Thanks a lot!!
Kathryn
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
