Python front end support for OpenVINO tool kit
Sreedhar_V_Intel
Is there a plan to enable Python front end support for Open VINO tool kit?
Severine_H_Intel
Dear Sreedhar,
We have a Python API for the IE and you can see it in use in our Python samples in the R2 and R3 release. The samples can be found in the samples folder at the following path: computer_vision_sdk_2018.3.343\deployment_tools\inference_engine\samples\python_samples.
Best,
Severine
Mark_L_Intel1
Hi Sreedhar,
Can you more specific what "Python front end" mean?
Mark
Sreedhar_V_Intel
Is it possible to use Python as front end to develop sample[eg:hello_classification/main.cpp] with inference engine?
Severine_H_Intel
Dear Sreedhar,
Best,
Severine
Mark_L_Intel1
Hi Sreedhar,
As a start point, you can run python API from the command line which gives you a convenient to do a quick try.
But you have to run the shell script to set up PYTHONPATH:
$ source <OpenVINO Install Dir>/bin/setupvars.sh
$ python3
Python 3.5.2 (default, Nov 23 2017, 16:37:01)
[GCC 5.4.0 20160609] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> from openvino.inference_engine import *
>>> net = IENetwork.from_ir(model="<OpenVINO Install Dir>/deployment_tools/intel_models/face-detection-retail-0004/FP32/face-detection-retail-0004.xml",weights="<OpenVINO Install Dir>/deployment_tools/intel_models/face-detection-retail-0004/FP32/face-detection-retail-0004.bin")
>>> plugin = IEPlugin(device="HETERO:FPGA,CPU")
>>> plugin.set_config({"TARGET_FALLBACK": "HETERO:FPGA,CPU"})
>>> plugin.set_initial_affinity(net)
>>> for l in net.layers.values():
...     if l.type == "Convolution":
...             l.affinity = "CPU"
[2]+  Stopped                 python3
You can refer to the Python API introductions for further help.
Mark
