6584 Discussions
dogsvscats custom caffe models - failed
I am following steps in github page: https://movidius.github.io/blog/deploying-custom-caffe-models/
There was a problem happened when I proceed to 2.Profile , I got “Error importing caffe” (see attached screenshots), and was not able to generate graph file.
I tried to re-compile CAFFE (I am using GPU version CAFFE) however no luck.
BTW, there are two failed tests after running “make runtest”(see attached screenshots).
Could you advise what possible solutions do we have? Many thanks.
Michelle
https://drive.google.com/open?id=1VIhDS3uQYu4bD0ETSmLTyQ7b0uy6K7_F
https://drive.google.com/open?id=1W61qj5Z4k4PsWuWBok8lpB2Yht7lrYmR
@micliu02 Did you have any issues installing the NCSDK? Try using the Caffe that is built with the NCSDK. If your NCSDK installed properly, you can set the pythonpath to /opt/movidius/caffe/python and see if you can run mvNCProfile.
